Headlight question and recommendations
5 replies to this topic
  • ThrakenH04
Posted December 12, 2004 - 04:16 PM
Ok well I love the feel of my bike right now and I have about $350 to spend and figured for what I was doing, I want a headlight. I know I need a lighting coil and brackets but could someone show or explain to me how the process works and how its installed plus where I could get the 2. Thanks in advance and I love my YZ450. I would perfer it if I could go toward getting either a aftermarket headlight assembly or the WR one.
  • ThrakenH04
Posted December 12, 2004 - 06:08 PM
anyone?
  • thumper245
Posted December 12, 2004 - 09:02 PM
I would be interested also although I have a 400f
  • Jackazz
Posted December 13, 2004 - 12:21 PM
I can't awnser your ?'s, but I'd say the best way to start would be by asking in the WR forum. Alot of guys over there have invested alot of time "YZ-ing" their WR's, & removing the headlights & brackets, & in some cases, the starters & other electronics. You might be able to find someone in there who'd know what you need & be willing to sell you the parts they took off their bike for a reasonable price.
  • yzwiley
Posted December 14, 2004 - 08:17 AM
After some research and having a lighting stator on order with E-Line for two months I found Baja Designs to have the best solution for me.
I simply called these guys up and told them what I wanted. They put together a kit to do exactly what I wanted. I received an external lighting coil assembly, a new shifter lever, a wiring harness, a brake switch, headlight switch, headlight, taillight, and instructions. It was simple to install and the help I received from Baja Designs was great.
I recommend you give these guys a call, for they do have a solution for you.
  • MXKyle
Posted December 14, 2004 - 09:47 AM
Check with these guys. I use a HID light to do night mountain biking and it is totally unreal. I would def go with a HID system if I was installing a light.
HID Light systems
Good luck,
--KT--
  • 5 replies
  • Hot  50 replies
  • Hot  47 replies
