Time for larger fuel tank.05 WR450
9 replies to this topic
  • onelugnut
Posted December 11, 2004 - 01:17 PM
What are some pro's and con's about different tanks.I would like something that will bolt right up.
  • jbarnes
Posted December 11, 2004 - 04:19 PM
IMS will have one that clears the AIS soon, if you remove it the current tank fits.
  • Ferd Woodstock
Posted January 01, 2008 - 10:18 AM
I put an IMS on my 05 with the standard shrouds. Appears to be a good quality tank and went right on. Looks pretty good too.
  • clark4131
Posted January 01, 2008 - 10:55 AM
Acerbis 3.4! I put one on mine and I never looked back. The only thing I would do is get some 1/4" Motion Pro Tygon fuel line and use that instead of what is supplied with the tank, and maybe a 5/16" brass fuel tee...SC
  • cpr1
Posted January 01, 2008 - 04:21 PM
The Acerbis 3.4 fits very well and is almost as slim as stock. The extended range is always a big plus.:banghead:
  • tonymillertnt
Posted January 01, 2008 - 05:02 PM
Does the Acerbis 3.4 fit the "07 WR450's?
  • cpr1
Posted January 02, 2008 - 01:27 PM
As long as it's for the 2007 model it will fit. The 2006 Acerbis 3.4 tank will not fit the 2007 model properly.
  • blackdog9
Posted January 03, 2008 - 06:00 AM
Here´s mine:
  • Seabass
Posted January 03, 2008 - 02:07 PM
On my '05 I had both the Clarke tank and the IMS tank. I ended up sticking with the IMS tank mainly for the larger capacity. Both were nice and fit fairly well. I didn't like the twin petcock the IMS needed though. The gas line ran very close to the heade on the right hand side.
  • SXP
Posted January 03, 2008 - 04:43 PM
Here´s mine:
What is the capacity of that tank? Also, I see that you will never be able to use the full capacity as the petcock is positioned about midmay along the side of the tank and not at it's lowest point.
