Question on tightening front axle
5 replies to this topic
  • michaelschorpp
Posted December 10, 2004 - 02:04 PM
Sorry if this is a very basic question, but I just changed the front tire, and when I went to tighten the axle holder nuts I noticed something odd. There is a 3/8" gap in between the fork and the odometer casing where the front axle is visible. Should this gap be closed before tightening the axle holder nuts?
Mike.
  • BrianVT
Posted December 10, 2004 - 02:17 PM
Not sure what your axle looks like but I think mine tapers down right at the odometer drive, so the space shouldn't matter. I wouldn't push the fork in if it doesn't want to be there.
If your odo. drive can move away from the hub you've got a problem.
Hopefully your forks aren't bent. You might check them by loosening the triple clamps and turning them to check for runout.
Good luck
  • roosterk0031
Posted December 10, 2004 - 02:43 PM
Mine has a similar gap. I believe the shoulder on the axle holds the od drive in the right position. The clamp area (shoulder) is larger than the rest of the axle. All from my memory and it's not to good. David
  • BWB63
Posted December 10, 2004 - 06:03 PM
Before you tighten the axle cap, the axle is torqued to 65 foot pounds. For the can 9 pounds for the two top nuts first then the bottom nuts .
  • tirebiter
Posted December 10, 2004 - 09:02 PM
Here's the deal- Tighten the axle, hold the brake & bounce the front end up and down as hard as you can three or four times. This process aligns the forks- reducing binding, premature seal wear and seal leakage. After you've done that, tighten the pinch bolts..
  • roadcam
Posted December 11, 2004 - 04:57 PM
I never heard of the wheel-bounce deal....sounds good to me...thanks for the new tip ...
  • 17 replies
Honda XR650L 2017
  • 0 reviews
  • 9 replies
Washington
  • Hot  32 replies
  • Hot  35 replies
