Backfire
3 replies to this topic
  • DelTronXR
Posted December 09, 2004 - 07:03 PM
I've got a 2003 BRP and when it's not warmed up all the way, it backfires, and it even does it after warmup (just not as much/dramatic) on the throttle braking. I've got a 172 and a 68, an applied smog block off, pro-circuit head pipe and silencer, hrc manifold, and a Uni filter. Why the hell does it pop so much? You'd think I was running 110 octane Turbo Blue or something that was exploding out of the bike's butt! :cry:
  • qadsan
Posted December 09, 2004 - 09:11 PM
Try adjusting the fuel screw per the service manual or see this link for more info. It's free to try and it might help.
http://www.xr650r.us/xr650r_faq/#14A
  • XR6's_rule
Posted December 09, 2004 - 09:35 PM
Sounds like you've got an exhaust leak, check the tightness of the clamp where the header joins to the muffler and where the headers join to the cylinder head, while you're down there, check for black soot stains around the joins-sure signs of the joint leaking, which causes backfire. Failing that, give everything a good clean in the carby and make sure the airscrew is set correctly. Good luck! :cry:
  • frankstr
Posted December 10, 2004 - 05:19 AM
Hows the valve adjustment,a tight valve lash will make it backfire :cry:
  • Hot  29 replies
  • Hot  35 replies
  • 17 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
