XR600 Fork Oil
5 replies to this topic
  • SteveJC
Posted December 09, 2004 - 05:41 AM
Sorry to ask something that I'm sure has been asked a zillion times - what grade oil should I use? - stock stuff seems OK for me - what weight is ATF that the manual says to use??
Thanks
Steve
  • HairyScary
Posted December 09, 2004 - 11:56 PM
I believe it is PJ1 that markets an "ATF weight" oil that they also list as 17W. Most ATF are ISO 37 or thereabouts, so if you can find an ISO number for the fork oils you have available, maybe that will help. Or you can simply use ATF. NOte that only the older XR600 used ATF, newer ones with ther cartridge fork specify 5W I think. (Oh, by the way, ATF = Automatic Transmission Fluid.)
  • SteveJC
Posted December 10, 2004 - 12:09 AM
Thanks Hairy :cry:
I think you have confirmed the important bit - I have an old workshop manual but my bike is a 98 model, so hence cartridge forks. I put some 5W in them last night which seems to be the same as the snot that was in originally (but a lot cleaner obviously!!). At least I have a reference point now if I want to experiment.
Interesting trawling the web as ATF is quoted as anything from 0/20W to 30W, and many in-between! And some have said it eats seals as well. Bizarre.
Thanks
Steve
  • HeadTrauma
Posted December 10, 2004 - 05:07 AM
Not that bizarre. Its just a simple case of most people not knowing what they're talking about. It happens alot with cars too.
  • michaeln
Posted December 10, 2004 - 05:20 AM
Honda specs Honda SS7 fork oil for those forks, which is 5WT.
  • roadcam
Posted December 10, 2004 - 05:28 PM
its always been explained to me, that ATF actually has two factors that seperate it from the engine oils.... it handles high heat better, and it has Seal preservatives in it ... ( I also know it has a very high detergent action, therefore diesel engine manufacturers actually clean used fuel injectors by boiling them in ATF prior to rebuilding them ) ...
Honda XR650L 2016
  • 0 reviews
  • Hot  29 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
Honda XR650L 2017
  • 0 reviews
