I have a buddy w/ a WR 250F w/ aprox. 110 miles on it.He's done a couple of oil changes on it w/ the normal yamalube oil.The shifter is real notchy from 2nd.-1rst, and harder to find nuetral too!(w/or w/o the clutch pulled). We thought this would smooth out over the breakin period w/ miles of riding..But @ 110 miles still there! It's a real PAIN! to start also..I think that's due to stock jetting and we are @ 3000' and higher..I have a WR426F and the shifting is as smooth as glass!.....Any help would be great!.....Thanks.......Tim
Notchy Shifter??
Started by HAYESTI, Jul 08 2001 08:29 AM
5 replies to this topic
Posted 08 July 2001 - 08:29 AM
Posted 08 July 2001 - 03:16 PM
Tim, two things...first the clutch pressure plate is JUNK! Take it out and smooth all of the burrs you can find on it. I actually beveled (slightly) the inner edge where the pressure plate hits the clutch plate. That completely solved my clutch problem. I can get neutral every time now no problem! Second...raise the idle! mine was also a nightmare to start until I raised it. Now I hardly use the hot start. BTW, I used an air angled die grinder with a small Scotchbrite pad attachment. IT smoothed the plate perfectly!
Randy
Randy
Posted 08 July 2001 - 07:18 PM
Thanks for the reply,Randy.. The thing I was wondering about is I have a 01 WR426 and do not have the problem w/ the notchy shifting, and was wondering if it was a warranty item being so new?...Thanks again for the info!!......Tim
Posted 08 July 2001 - 10:47 PM
Warranty??? Yamaha???? I'm starting to think those two words don't go together!! I started using Amsoil at about 175 mi. and the notchy shifting got a lot better. As far as warranty...forget it. Over 30 days and they don't know you anymore!
Randy
Randy
Posted 09 July 2001 - 02:44 AM
You can control this. Take off the right side cover and under the clutch is the notched wheel that controls gear selection. The ramp for neutral is huge: between 1st and neutral--- and between neutral and 2nd. You can file these 2 ramps down a bit and your 1-2 shift (and 2-1 shift) will become as smooth as your other gears. Actually I went a bit too far and those two shifts on my bike are actually the smoothest on the whole gearbox now. Neutral becomes a bit more tricky to find but that is a good thing. Its kind of fail safe too. If you screw something up (its really hard to) it will only cost you about $38 for a new part.
