barbarian,
when you said you lowered your needle one clip position I am inferring you met groove 4 which would be a richer setting than standard (groove 3). I think this is your problem. I would go to groove position 2. If you don't see an improvement you probably have bigger problems as Randy stated.
My bike has yz timing, vortip, grey wire disconnected. I am running a 175 main, needle position in groove 2 and my bike runs great. The density altitude here in phoenix today at maximum temp was about 4000 feet. Your density altitude in columbia today was about 3100 feet. Our density altitudes are not to far off so I would suspect our bikes to be jetted similarily. For the most part conditions here in the summer are going to be a little leaner setting wise (standard set up would be too rich) then where you are at. I suspect I may be a little rich with my 175 main but It seems to still run pretty good. If going leaner on the clip solves your low end problem and the high end doesn't improve you might try the stock 170 main.
To answer braindamage's question density altitude is pressure altitude corrected for temperature. ok what the hell does that mean?
Pressure altitude is based on standard day conditions which means at 59 degrees farenheit and sea level altitude (0 feet) a mercury barometer would read 29.92 in of Hg (mercury). At these standard sea level conditions if the outside (ambient) temperature is higher then 59 degrees you will have an air density which is lower than standard thus giving you a higher apparent altitude. Therefore, density altitude gives a convenient way for everyone to make measurements using the same yardstick (so to speak). Here is a link which allows you to calculate density altitude.
http://rshelq.home.s...com/calc_da.htm
Relative humidity usually plays a smaller effect then the ambiemt temperature condition but is included in the calculation.
My altitude here in phoenix is about 1100 feet above sea level. If I take current weather conditions and input them into the link above I get a density altitude of 3100 feet. This means the altitude here right now is equal to 3100 feet based on a standard day. The key is that if we all compare density altitudes we are using the same baseline, and as a result the comparions are apples to apples.
Hope this helps!
Gear_Head
