Rekluse setup
5 replies to this topic
  • coulterk
Posted December 07, 2004 - 12:58 PM
My rekluse for my YZ426F arrived today and I have been reading the installation instructions and I am not sure on the installation of the external adjuster. The photo in the instuctions shows the actuator arm and support bracket but looking at my bike the support bracket bolts on to a vertical surface at the base of the barrel but in the photo it appears to be bolted to a horizontal surface behind the barrel. Also the actuator arm points towards the rear of the bike whereas mine points across the bike.
So my question is how do I install the external adjuster and does anyone have any photos of the installation on a 426.
Thanks for your assistance.
Kaj :cry:
  • tool
Posted December 07, 2004 - 01:37 PM
the external adjuster mounts on the perch, not the engine.
but then again, im not even sure i understand your question.
  • GENE426
Posted December 07, 2004 - 01:55 PM
did you see this with good pics
http://www.rekluse.c...r450-082604.PDF
let me know how the clutch works
im intrested in one myself
  • coulterk
Posted December 07, 2004 - 03:11 PM
I am talking about the basic external adjuster where the spring attachs to the clutch actuator arm and not the perch adjuster.
  • coulterk
Posted December 07, 2004 - 03:19 PM
Thanks GENE426 for the pictures. The 04 YZ picture is the setup that I have to use. The pictures in the YZ426 instuctions are the same as the 03 YZ and 03-04 WR. Yamaha must have changed the setup from the after the 01 426.
I will let you know how it goes. I hope to install it tomorrow and ride on the weekend.
  • coulterk
Thanks GENE426 for the pictures. The 04 YZ picture is the setup that I have to use. The pictures in the YZ426 instuctions are the same as the 03 YZ and 03-04 WR. Yamaha must have changed the setup after the 01 426.
  • Hot  50 replies
  • Hot  47 replies
  • On January 15, 2017
  • 5 replies
