need a new kick starter
21 replies to this topic
  • fndaway66
Posted 27 June 2001 - 12:57 PM
Hey guys I am looking to by a new kick starter. The stock one is pretty chewed up. Also would I need to get new foot pegs to stop this new kick starter? and while I at it I would like to replace the rear brake fin, any ideas.
  • Husker_Mike
Posted 27 June 2001 - 04:49 PM
My kick starter is getting really chewed up, too. I know BBR makes a super deluxe one, but it's around $170 or so. Makes me wonder, though, how long that one will stay super deluxe until the peg chews it apart...
  • BikeDestroyer
Posted 27 June 2001 - 05:02 PM
I'd say go with DH Racing for the rear shark fin and BBR for the kick starter.
  • BadgerMan
Posted 28 June 2001 - 02:48 AM
Tig weld the stop on your foot peg to make it wider extending it in towards the engine. The stop on my peg is probably three times its original width now. Then, bolt a piece of 1/4 inch thick conveyor belt material to the back side of your peg to cover the stop area. If done properly, it won't interfere with the folding of the peg. I installed a new kickstart lever back in February and still looks like new without a scratch on it!
  • W-Ride
Posted 28 June 2001 - 08:28 AM
I started out chewing up my kick-starter lever and thought I'd be replacing it. Then I learned how to kick-start without ever touching the footpeg. It's all in the technique (not saying I have much). What I do, though, is lean forward way over the gas tank and kick back more instead of down...my foot rarely goes down far enough for the lever to hit the peg. YMMV. Wride.
  • BadgerMan
Posted 28 June 2001 - 08:47 AM
Yeah, I pretty much avoid hitting the stop too anymore. I usually start it without ever lifting my butt off the seat. It is really that easy once you learn how and have everything (fuel screw) adjusted correctly.
However, my lever did not line up with the stop on the peg as delivered. If you hit bottom when kicking, the lever stuck down. When I replaced the lever, the new one lined up perfectly with the stop on the peg.
The design intent was for the lever to come in contact with the peg and if they line up correctly there is no problem. Obviously, there is variation from lever to lever and/or bike to bike. A rider should not have to develop a special starting routine to compensate for a lack of control during the manufacturing process for the lever.
  • WRecker
Posted 28 June 2001 - 09:02 PM
I experienced the same problem with my bike from day one. Since the bike was still under warranty, they replaced the kicker with a BBR piece, free of charge (of course, BBR hadn't got their replacement lever to market yet, so I had to wait about a month and a half). The BBR lever is a stout piece, and a bit shorter (which I really like), but the finish was less than up to their usual standards, and it's still chewing itself to bits on the odd occasion that I stuff it into the footpeg.
  • TheBOS
Posted 28 June 2001 - 09:26 PM
Devol makes a replacement kick starter as well.
  • WRecker
Posted 28 June 2001 - 09:53 PM
Devol's piece is BBR. They're located next door to each other in Enumclaw, WA.
  • teton
Posted 28 June 2001 - 05:33 PM
I have a BBR kick start lever still new in the bag for sale, selling bike due to injury.
$150.00 and Ill include shipping
dlbcrasher@msn.com
714 271 8331
  • jimt_yz400
Posted 31 October 2001 - 12:09 PM
Teton,
Still have the kickstarter for sale?
  • Don_Thompson
Posted 31 October 2001 - 01:42 PM
for the sharkfin check out BRP
BRPIT.COM
  • fndaway66
Posted 31 October 2001 - 02:30 PM
yz400 I bought Tetons Kickstarter awhile back.
Don thanks for the info but already purchased one from Scott's.
  • fraser
Posted 31 October 2001 - 11:15 PM
I got a BBR, so my standard one is up forsale if anyone wants it, buyer pays postage from UK
  • ron_i
Posted 01 November 2001 - 06:46 AM
there's another brand called pro-tec which is also shorter than stock and a little less money than the BBR starter.
a couple folks i know have the BBR. it makes the 250F start like a 125 2-smoke.
  • chr_bailey
Posted 01 November 2001 - 10:55 PM
I installed the Pro-Tek and basically solved my hot starting problems. Instructions have you bend the #3 rear footpeg tooth in (use Vice grips with electrical tape on teeth) so it doesn't chew up the kickstarter. Seems to work, but I agree with others that if you modify your kicking technique you can avoid the problem altogether.
  • Mook
Posted 01 November 2001 - 10:59 PM
<BLOCKQUOTE><font size="1" face="Verdana, Helvetica, sans-serif">quote:<HR>Originally posted by chr_bailey:
I installed the Pro-Tek and basically solved my hot starting problems. Instructions have you bend the #3 rear footpeg tooth in (use Vice grips with electrical tape on teeth) so it doesn't chew up the kickstarter. Seems to work, but I agree with others that if you modify your kicking technique you can avoid the problem altogether.[/QUOTE]
Is there a website for this kickstarter?
mook
  • 250F#8
Posted 01 November 2001 - 02:34 PM
<BLOCKQUOTE><font size="1" face="Verdana, Helvetica, sans-serif">quote:<HR>Originally posted by WRecker:
Devol's piece is BBR. They're located next door to each other in Enumclaw, WA.[/QUOTE]
DEVOL IS IN EMUMCLAW AND BBR IS IN KENT I HAVE BEEN TO BOTH OR HAS BBR JUST MOVED..
  • 250F#8
Posted 01 November 2001 - 02:36 PM
WRECKER WHER DO YOU RIDE I LIVE IN PUYALLUP TOO
  • Wah_Bah
Posted 02 November 2001 - 08:02 AM
<BLOCKQUOTE><font size="1" face="Verdana, Helvetica, sans-serif">quote:<HR>Originally posted by 250F#8:
[/QUOTE]
BBR is now in kent.
