say that ten times fast
The 250F will definitely not have the peak horsepower of a 250 2 stroke. It will have more bottom end than a MXr and rev comfortably much higher. It likes to be revved high.
IMO - To be competitive on it you would have to take advantage of the wide RPM range of power it has. In a sense, once you get going, pick a gear and stick with it as much as possible - clutch it like a 125 rather than downshifting - rev it to the moon. Actually rev it until the rev limiter is about to kick in.
The modifications needed to make it competitive are easy (now that you have found this place) and usually only cost some of your time. Get one and start asking questions - you will find plenty in the archives too.
What you will be disapointed with is the ability to start it - at first. Trust almost everyone on the WR forums - you will get used to it and wind up thinking it is easy. It took me half an hour to get it started the first time - and now one or two kicks does it hot or cold.
- Sean
