Indy Wr450 I have a jetting?
3 replies to this topic
  • onelugnut
Posted December 06, 2004 - 08:25 PM
You seem to have a good grasp on jetting the 450.I have a 05 WR450 that has been uncorked and JD jet kit.Can you recommend a starting place on jetting this thing.I Will ride elevation 2000-4000' and 30-45* until summer then 6000-8000' and 70-80* Best guess is ok.
Thanks lug :cry:
  • Indy_WR450
Posted December 06, 2004 - 08:37 PM
Punch a couple of 1" dia holes in the side of the airbox and place aftermarket foam plugs to help the uncorked jeting work better.
30 - 50 degrees @ 3,000 feet elevation: 170 main, JD Blue #5, 48 pilot, 72 starter jet, #40 leak jet
50 - 70 degrees @ 3,000 feet elevation: 165 main, JD Blue #4 , 48 pilot, 72 starter jet, #40 leak jet
70 - 90 degrees @ 3,000 feet elevation: 160 main, JD Red #4, 45 pilot, 68 starter jet, #50 leak jet
50 - 70 degrees @ 7,000 feet elevation: 160 main, JD Blue #3, 45 pilot, 68 starter jet , #50 leak jet
70 - 90 degrees @ 7,000 feet elevation: 155 main, JD Red #4, 42 pilot, 65 starter jet, #60 leak jet
Those are all tested with uncorked stock pipe and air box mod holes to increase air flow into the air box. :cry:
  • onelugnut
Posted December 07, 2004 - 07:01 AM
Thank you :cry:
  • onelugnut
Posted December 07, 2004 - 03:56 PM
:cry: Where did you get the leak jet from the dealer doesn't have a part number.Go figure
