How to tell '00 426 from '01
12 replies to this topic
  • zeroseven
Posted December 05, 2004 - 08:23 AM
Is there any discernable external difference ??
  • Satch0922
Posted December 05, 2004 - 08:50 AM
graphics, VIN number,
  • sirthumpalot
Posted December 05, 2004 - 10:12 AM
I think the front brake rotor may have changed in size by 10mm (larger on the 01'). Can someone back me up on this?
  • zeroseven
Posted December 05, 2004 - 10:13 AM
Is there a site to check the VIN number ?(its a UK bike).
  • CRFThumper
Posted December 05, 2004 - 02:28 PM
Was this not the 1st year for the floating roter as well?
:cry:
  • Matt96xr6
Posted December 05, 2004 - 03:01 PM
if the bike is stock, graphics and the front brake system is how you tell them apart.
The 00 bike has a fixed rotor and akebono master cylinder
the 01 bike has a floating rotor (has rivets in it) and a nissan MC
  • yzf205
Posted December 05, 2004 - 07:27 PM
If the bike has the 5 valve titanium sticker on the side it's an 01.
  • Matt96xr6
Posted December 05, 2004 - 07:54 PM
I can buy that sticker and put it on my 00 also. Not always a tel-tale sign there.
  • zeroseven
Posted December 06, 2004 - 12:16 AM
Hmmm. No sticker. floating disc but '00 clutch..., still unsure
  • Hick
Posted December 06, 2004 - 12:33 AM
The '00 had an Akebono front master, the '01 a Nissin. Easily switched, true...
I'm not sure about the disc, but as I remember it the '00 was fixed and the '01 floated.
The header on the '01 was a bit higher and cleared the oil filter cover, on the '00 you had to loosen and twist (or remove) the header to R&R the filter. Again, easily changed, a few '00 owners just wrenched the stock header up out of the way and made it permanent.
The '01 had a different carb needle, OBEJP stamped on the needle vs. OBEKR on the '00 (or something like that, the relevant difference is the letter J vs. letter K). Easily switched by the '00 owner (no sane '01 owner would use '00 jetting).
I had both but that is all I can think of. Look up the VIN.
  • zeroseven
Posted December 06, 2004 - 05:12 AM
Thanks everyone, it looks like its an '00. Never had a problem with the jetting (though I run it on the street) until now!! I'll order a needle.
Thanks again
  • tdd6405
Posted December 06, 2004 - 08:01 PM
the 00 doesnt have a hotstart on the carb. but the 01 does
(correct me if im wrong)
  • Hick
Posted December 06, 2004 - 09:06 PM
Okay.
The '00 hot start is on the carb, which was changed to a proprietary design beginning in that year.
The '99 hot start was plumbed external to the carb as you describe.
  • 0 replies
  • Hot  47 replies
  • 10 replies
