opinions on that magic grey wire
14 replies to this topic
  • ch0g
Posted December 01, 2004 - 01:27 PM
hey guys :cry:
i wanna know what everyone thinks about their grey wire experiences. some ppl say huge, others say none, let us know your setups :cry:
ch0g
  • timvv51
Posted December 01, 2004 - 04:10 PM
couldnt really tell a difference on my 03. Thing has more power than I need most of the time anyway.
  • Endurordr
Posted December 01, 2004 - 04:25 PM
This should be interesting. :cry:
  • cruise
Posted December 01, 2004 - 06:02 PM
i recon it made mine rev better more like my friends yz
  • obermeyer
Posted December 01, 2004 - 06:24 PM
No change I can tell
  • wrooster
Posted December 01, 2004 - 06:42 PM
guys,
just FYI
we studied the effects of the grey wire mod on the 250F:
http://www.thumperfa.../gray_wire2.htm
summary: on the 250F, it does indeed change the ignition mapping.
jim aka the wrooster
'01 wr250f
  • 5valve
Posted December 01, 2004 - 11:54 PM
euro models come with grey disconnected
it must be some restriction (environment, power)
  • Indy_WR450
Posted December 02, 2004 - 05:02 AM
Grey wire mod really works. Just do it. :cry:
  • thumpinTed
Posted December 05, 2004 - 04:29 AM
I noticed that the motor revved up quicker from the mid to top and possibly gained a few hundred rpm before the rev limiter kicks in, which I try to avoid. I also heard the gray wire on US model WRs when disconnected gives an additional 5 deg of spark advance. A stock WR is only capeable of 50% throttle opening (the stop that is cut or a YZ throttle stop installed) wont need any more advance if the TPS value is maxed at 50% in stock corked exhaust trim. Then theres the exhaust cam timing WR OR YZ
  • dirtr1der
Posted December 05, 2004 - 09:44 AM
Did the grey and blue wire at the same time. Seems to get close to the limit much quicker now. Mostly from mid range rpm.
  • purluvwr450
Posted December 05, 2004 - 09:47 AM
Blue wire?
  • Top
Posted December 06, 2004 - 06:24 AM
Blue wire?
Ditto :cry: :cry:
Why can't a guy just clip the grey wire, try it out and see if there really is a diffrence? If he doesn't like it, just hook it back up? :cry:
  • ch0g
Posted December 06, 2004 - 06:35 AM
blue wire?
  • Indy_WR450
Posted December 06, 2004 - 07:00 AM
Sky blue wire needs to also be pulled to improve spark voltage during start up.
This is independant of the gery wire mod. :cry:
  • Treebanger
Posted December 06, 2004 - 07:20 AM
Revs quicker in the mid range!!!
