Backfire?
31 replies to this topic
  • marcusmoberg
Posted December 01, 2004 - 09:31 AM
[COLOR=Blue]I have been having a problem with my muffler backfiring when I let off the throttle after high RPMS! What is wrong? Is it my jetting?[/COLOR]
  • glasseye
Posted December 01, 2004 - 09:37 AM
Probably isn't a back fire. It may actually be the engines exploding on the PW-70's that you are drag racing.
  • marcusmoberg
Posted December 01, 2004 - 09:41 AM
I was looking for an answer to my question! :cry:
  • glasseye
Posted December 01, 2004 - 09:45 AM
you will have better luck if you change your user id
  • simch
Posted December 01, 2004 - 09:54 AM
LOL!!
It does sound ike you may be a bit lean Marcus, try going up on the main or lifting the needle one click.
  • marcusmoberg
Posted December 01, 2004 - 03:28 PM
How do you do that? Do you have to take the carbuerator out? Do you have to buy a jet kit? :cry:
  • WR_Dave
Posted December 01, 2004 - 03:39 PM
IF it's just your muffler backfiring you should take that one off right away,it's probably gone bad.Put on a different one and keep drag racing any quad you come across. Now if you remove the carb, I definitly recommend installing a jet in it's place. LMFAO :cry: :cry:
  • marcusmoberg
Posted December 01, 2004 - 03:49 PM
Do you think I am stupid? It's probably the engine making it backfire. You Canadians!
  • WR_Dave
Posted December 01, 2004 - 03:54 PM
Yes---No Kidding---- and without your location being included , you may BE a stupid Canadian.
  • Gadsen
Posted December 01, 2004 - 06:56 PM
It wasnt backfire, it was a pot shot from a disgruntled TT'r who has to read your post here. :cry:
  • simch
Posted December 02, 2004 - 06:33 AM
Main jet is easiest to get to, just take off your float bown (bottom bit of the carb) and its screwed in the bottom. You can loosen the carb and twist it round to get access to the screws.
NEEDLE IS MORE TRICKY, LOOK AT THE MANUAL!
  • washinout
Posted December 02, 2004 - 12:39 PM
You may have an exhaust leak...
  • Indy_WR450
Posted December 02, 2004 - 12:55 PM
Just wait until next summer and it will stop backfiring! :cry:
  • ncmountainman
Posted December 02, 2004 - 01:32 PM
marcus is a ragin'cajun i remember from his last thread bombardment. cajuns started out as canadians,at least they had enough sense to move! :cry: did you eat gumbo before the backfiring started? :cry:
  • marcusmoberg
Posted December 02, 2004 - 07:05 PM
Or did you? :cry:
  • marcusmoberg
Posted December 02, 2004 - 07:06 PM
Thanks for the info! :cry:
  • marcusmoberg
Posted December 02, 2004 - 07:08 PM
You think so? How can I tell if I do?
  • RichBaker
Posted December 02, 2004 - 07:31 PM
plug the end of the muffler....if you hear exhaust escaping you have a leak.....
  • BURLEY
Posted December 02, 2004 - 10:03 PM
Replace your Powerband.
  • Indy_WR450
Posted December 03, 2004 - 03:22 AM
LOL! :cry: :cry: :cry: :cry:
