XR 600 speedometer
7 replies to this topic
  • Pengaleng
Posted December 01, 2004 - 06:25 AM
Does anyone know if there is any available alternative to the Trail Tech speedometer motorcycle computer???
I know that this unit is jam up, but was looking for an alternative.
This will be for a 93' XR600
  • 600ish
Posted December 01, 2004 - 08:28 PM
I'm going to buy the ICO Dualsport for $120 from www.bajadesigns.com which is supposed to be much tougher than the Trail Tech. I know that ICO makes the Rallysport as well, which has many more features at quite a bit more. Good Luck, Walt
  • HeadTrauma
Posted December 01, 2004 - 10:28 PM
Not that long ago ATK had a pile they were getting rid of cheap. alot of people bought two because it was such a deal. You might find someone with a spare they'll sell you.
  • lucky_logger6
Posted December 01, 2004 - 11:08 PM
I had been trying to get one of the ATK units but ended up modifying a $10 bicycle computer form walmart to work on my XR400. Depending on the features you are looking for in a unit this may be a cheep alternative. I JB welded the magnetic pickup in the front rotor and lengthened the wire with light speaker wire. The whole install only took an hour and a half and a couple beers
  • dale
Posted December 02, 2004 - 03:37 PM
I bought 2 of the ATK ones and after using one was a little disappointed you can't preset the odo, only reset to zero (Only a problem in enduros). Other than that is is great. So if you want the 2nd one let me know.
  • buffalo
Posted December 02, 2004 - 03:51 PM
Hello! I just posted for putting a speedo on a CRF 230. If you want the factory Honda set up, you can find the parts at Bike Bandit.
  • dale
Posted December 03, 2004 - 04:00 AM
By Honda parts you mean the drive parts at the wheel? I assumed the XR600 already had that stuff stock, and just needed the actual speedo.
  • BadlandZ
Posted December 21, 2004 - 09:57 PM
Do you have, or could you take, photos and explain exactly how you mounted it? I'm planning on trying this on my wifes TT-R125LE.
