A little dissapointed
6 replies to this topic
  • jbrooks26
Posted December 01, 2004 - 04:32 AM
Ok, maybe you guys can tell me if I am full of it or not. I bought an 02 WR426 leftover from the local shop last year. I had read all of the posts about free mods and how the WR uses the same motor as the YZ and all that jazz. I have done most of the free mods, and I am still not happy with the throttle response. It is nowhere near as snappy as the YZ400 I had. (God help the guy I catch riding that thing) Anyway, Have I simply not got it tuned propperly yet or am I wasting time trying to get it to run like the YZ? I have done the BK mod, cut the grey wire, shortened throttle stop, modified air box, toyed with the jetting, YZ timing, and still can't get the crisp throttle respose that I had with the YZ. I realize that they have different tranny's, but what I am finding is that there is a very slight hesitation when I hammer the throttle. Anyone have any ideas? Thanks,
  • simch
Posted December 01, 2004 - 05:24 AM
Sounds like a jetting issue to me, if there is hesitancy. My 450 is real smooth on to the gas, but has a little stutter or so on cruise, caused by the TPS I believe.
  • huskyrider
Posted December 01, 2004 - 05:29 AM
Have you changed the needle or just the main jet?
My WR's got considerably snappier when I went to the YZ jetting in addition to the timing mods. It's been a few years since I did it and I don't remember the exact combo. I think it was EJQ and a 168. There were some real good jetting threads back then. I wonder if the new TT keeps those older threads in the search memory.
See Ya,
  • woodsk
Posted December 01, 2004 - 07:51 AM
The JD jetting kit sold here on TT should do it. The WR are pretty lean from the factory and until I re jetted I had the same off idle stumble you are describing. It starts much better also :cry:
  • Indy_WR450
Posted December 01, 2004 - 05:32 PM
It is all jetting! Search for the BK mod and jetting should get rid of your hesitation. :cry:
  • jbrooks26
Posted December 01, 2004 - 07:08 PM
I've done the BK mod, however I am not certain that it is set correctly. When I installed it I originaly set it without a stopwatch. Then after installing the carb back onto the bike I adjusted it for what I judged to be best throttle response. To tell you the truth, I didn't notice much difference from stock. This is the first carb work I have ever done so I am very much still in the learning phase. I should probably reset the BK mod to .3 seconds or so and then leave it alone while I try to fine tune the jetting. If you have any more suggestions please let me know. I have not changed the needle, but I have played a little with the needle position. Thanks,
  • huskyrider
Posted December 01, 2004 - 08:48 PM
I really wouldn't worry much about the stopwatch, just try to time it to where you get a slight shot right under the slide on its way up.
I think you'll notice a difference with a YZ needle.
If I remember correctly another popular combo was an EMM with a 160 or 162, going for the slimmer needle allowed them to lean the jetting with good results.
I'll search for some of those threads and post links if I find them. They were in late 01 and up into 02.
I know a lot of guys here have got great results with the JD jetting.
See Ya,
