Need Help!!!
6 replies to this topic
  • Derekj426
Posted November 30, 2004 - 12:59 AM
Ok, have a bit of a problem here.. Got an 01 YZ426F.. The hex bolt for the oil filter cover won't tighten all the way down, its stripped. Only tightens down a little bit but it doesn't feal like its enough.. What can I do? Run a lil longer bolt to reach the undamaged threads or what? Not sure how to fix this :cry: :cry: :cry: :cry:
  • alfie
Posted November 30, 2004 - 04:11 AM
Tou could try running a thread tap down the hole very gently, if memorey servers me right its about 6mm. hope this helps. :cry:
And dont rush it take your time.
  • yz426onNOS
Posted November 30, 2004 - 02:48 PM
Heilicoil
  • Satch0922
Posted November 30, 2004 - 03:16 PM
Mine has been like that since Sept 2002!!
I just make sure its the last bolt I put back in and I use teflon tape on the threads......never a leak and still going. I just snug it down when I put that bolt in.
If your not comfortable with that then heli coil it.
  • Derekj426
Posted November 30, 2004 - 04:45 PM
I got a bolt from the yamaha dealership that is about 1/4 inch longer then the stock bolt and I put it in with no problems and it tightened down and no leaks.. Wouldn't that work? The threads go back farther then what the stock bolt reaches or am I blocking something that I'm not aware of?
  • Satch0922
Posted November 30, 2004 - 04:57 PM
you should be fine.
  • Derekj426
Posted November 30, 2004 - 05:02 PM
cool, thx for the info about the helicoil, and putting teflon, was brain loacked and couldn't think of anything but maybe a longer bolt, duh...
  • Hot  38 replies
  • On January 15, 2017
  • 10 replies
  • Hot  28 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
