Tripple clamp????
10 replies to this topic
  • woodsk
Posted November 28, 2004 - 06:29 PM
I'm gonna go to some fat bars (by "go to" I mean purchase 1 1/8 handlebars, not go to a bar that caters to large people) on my '04 450, so I was thinking about buying a new top clamp as well instead of just adaptors. I've never bought a aftermarket top clamp before, so my question is; is it worth the cost? I think I can get the bar position and height I want without a new top clamp, I'm not concerned about weight savings. So I just can't think of a reason for spending the money. Any thoughts?
  • patrickincc
Posted November 28, 2004 - 06:49 PM
Look at Ride Engineering. I put them on my CRF 250 X, there nice and seemed to be cheaper then RG-3. There are allot of others, applied, etc.
  • patrickincc
Posted November 28, 2004 - 06:58 PM
also look at http://www.brpit.com...s.html#guardpkg
  • patrickincc
http://www.brpit.com...ple_clamps.html
  • mtrablue
Posted November 28, 2004 - 07:38 PM
if your pretty sure you'll be happy with adapters, go for it. i went to a brp top clamp. i wanted to be able to adjust position but i also wanted to go to rubber mounted clamps.
  • simch
Posted November 29, 2004 - 04:48 AM
Aftermarket triple clamps are generally heavier than stock, but off rubber mounts, adjustability and or different offsets. If all you want is the fat bar, I would go for the adapters, a way cheaper option.
  • Treebark
Posted November 29, 2004 - 08:15 AM
I'm using Applied Triples can't adjust positions with them but where the cheapiest. Can't use adjustable with a scotts dampener unless you buy the right bar clamp and I had a std kit and I'm short so adjustablity wasn't a big deal. Universals are nice with the rubber mounting and adjustable but had problems with getting a set that fit my bike since the 04 YZ and WR are different size forks. I bought mine from MotoSport Outlet but can get them cheaper at BTO SPORTS . I'd check with TT store. :cry:
  • ncmountainman
Posted November 29, 2004 - 08:22 AM
03 yz fits 03-04 wr :cry:
  • BIGMatt
Posted November 29, 2004 - 08:32 AM
I bought these for my bike. A perfect fit, adjustable, and inexpensive. I added Renthal Fat Bars too.
http://www.rockymoun...tv?pid=00092069
  • Dan_Lorenze
Posted November 29, 2004 - 08:44 AM
I'm selling this Protaper topclamp on ebay right now, one day left....
This topclamp is for the 00-03 YZ that slipped on to my 03 WR with no problems..
If I could give my .02 on topclamps, the adjustable ones are nice but some of them won't let you mount a dampner on them. You might not want to use a dampner on your bike now but might want to in the future.
  • Jackazz
Posted November 29, 2004 - 08:51 AM
I'm using Applied Triples can't adjust positions with them but where the cheapiest...
Hey Treebark, I'm not 100% sure, as it's been awhile since I mounted mine, but if I remember correctly, there are two available positions for the bar mounts, one stock, & one farther forward, depending on which way you install the bar mounts.
