Fork Oil
7 replies to this topic
  • slappie
Posted November 26, 2004 - 07:13 AM
I've got a stock 04 450.
I want to add some fork oil to help resist bottoming.
Can I just add some Bel-Ray 5wt or do I have to get the Yamaha 01 stock suspension fluid?
Are the two oils compatible?
Also, I had a leaky fork seal that was caused by some dirt in the seal.
I got it fixed with the film negative trick.
Is there any easy way to measure the fork oil volume/height without fork disassembly? I think I lost a little bit of oil due to the leaky seal.
Thanks
Posted November 26, 2004 - 10:16 AM
The "01" spec in the manual is, according to both dealers I checked with originally, 5wt fork oil. Bel-Ray is probably compatible.
One problem with adding oil this way is that you may not know: a) what the current oil level is, and/or :cry: how much oil it takes to raise the level a certain amount.
If you exceed the maximum oil height, you won't like the results, so at least, pull the springs, set the bike on the ground, and measure and adjust the oil level accurately. Ideally, you should drain and refill. It's probably time to do that anyway.
  • Geezerx
Posted November 27, 2004 - 07:01 AM
You will be much happier if you follow gratracer's advice.
Start with fresh oil and an oil level that YOU know you set. Then you can experiment with adding or subtracting oil.
  • joer6
Posted November 27, 2004 - 08:50 AM
i was under the impression that yamaha 01 fork oil is the equivelant to 0 weight. :cry: i could be wrong.
Posted November 27, 2004 - 10:49 AM
That's not what I was told, as I said, by two different service departments (not parts guys). It gets even more confusing than that sometimes. When I asked for the "01" oil that the manual called for, I was handed a bottle of Maxima Fork Fluid "85-150" !! Further down the label, it says "5 Wt"
  • Scooter426
Posted November 28, 2004 - 06:54 AM
o1 is 5 wt oil. open up your forks and drain your old oil and put new oil in at the proper height. Get a fork oil height tool ($30). It is worth it. It works like a giant syringe with a depth controlled "needle". Very accurate for setting oil height.
I like the Honda standard fork oil. It seems to work better (higher quality stuff).
  • beezer
Posted November 28, 2004 - 07:05 AM
Factory Connection told me that the Honda SS oil is the best on the market.
  • Scooter426
Posted December 16, 2004 - 03:18 PM
beezer is right. Many rebuild shops like to use the Honda SS oil. It is a high quality fork oil.
  • Hot  36 replies
  • Hot  30 replies
  • Hot  38 replies
  • Hot  28 replies
  • Hot  50 replies
