Need Help-Throttle cable
6 replies to this topic
  • jasonYZ426NC
Posted November 25, 2004 - 02:22 PM
I just changed out a broken throttle cable on my 02 426. I think I did everything right, but there are 2 problems: 1. the throttle doesn't return by itself, it seems to stick even after adjustment 2. my bike wouldn't start and kept backfiring when i was releasing compression. I think by twisting the throttle to try to get the adjustment/return corrected, I may have flooded the bike. I don't want to dig this hole deeper. Any suggestions??
  • MXof21
Posted November 25, 2004 - 05:05 PM
Unhook the cables and make sure the carb operates smoothly by it's self. Assuming it does make sure that the cable operates smoothly when not on the carb, if it doesn't you have a problem with the throttle tube. Assuming the carb operates smoothly and the throttle tube operates smoothly make sure when you put it together the cables are snug but not overly tight. Hope this helps. Don't even try to start the bike if the throttle is not working correctly.
  • BC3
Posted November 25, 2004 - 05:14 PM
loosen the rear cable (return) on the throttle assy (handle bar) adjust front cable ( pull ) so that you have some play and the throttle will close by itself..
now adjust the rear cable (rerturn ) so that the throttle will just return by
itself, no tighter....thats how you adjust the cables...if you still have a problem
make sure the throttle tube isn't pushed onto the bar too far and rubbing inside
causing the throttle to hang-up.....
BC :cry:
  • yz426onNOS
Posted November 25, 2004 - 06:07 PM
Did you route the cables correctly? To un-flood the bike just pull the decompression lever and kick it 20 times.
  • jasonYZ426NC
Posted November 25, 2004 - 08:37 PM
Thank You!!! I'm going to check it out in the AM and I will report back.
  • jasonYZ426NC
Posted November 28, 2004 - 04:24 PM
All is well, got the throttle cable adjusted out to the park and it wouldn't start, but taking out and cleaning the plug fixed her right up.
Thank you for your help!!!!!
  • yz426onNOS
Posted November 28, 2004 - 05:40 PM
Glad we could help!
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  36 replies
Need help by Goforaride
  • Hot  68 replies
  • Hot  28 replies
