How do I remove stripped screws on carb?
13 replies to this topic
  • DoctorRzed
Posted November 25, 2004 - 04:07 AM
I wanted to take my carb apart and clean the carb but I found that all the screws are stripprd. Any ideas how to get them out?
  • mtrdrms
Posted November 25, 2004 - 05:12 AM
I had the same problem on my float bowl screws. I had to pinch then with small vice grips and if that doesnt work try notching them so you can use a big flat head screwdriver. Use the same size alan screws to replace them. I havent had a prob since.
  • yzf450jack
Posted November 25, 2004 - 09:02 AM
Put your screw driver on the head of the screw now smack the screw driver with a hammer :cry:
  • DoctorRzed
Posted November 25, 2004 - 11:26 AM
The screw is to stripped to even do that.
  • BC3
Posted November 25, 2004 - 11:38 AM
This is the only way your going to get them out now that their wollowed out..
BC :cry:
  • YZ250F_Rider
Posted November 25, 2004 - 11:49 AM
after you get them out replace them with hex screws.
  • yz426onNOS
Posted November 25, 2004 - 06:20 PM
That frees up the rust and corosion. Also use some penatraiting oil. You might have to use an easy out. Or drill them. A stud welder would work awesome!
  • smokin529
Posted November 25, 2004 - 07:56 PM
Mine did the same thing...Smallest vice-grips wouldn't fit...drilled off heads....Vice-Grips fit after I drilled heads off and got float bowl out of the way. Just be sure to clean out the carb extremely well before you put it back together with a little anti-seize on threads of the new bolts/screws.
  • smokin529
Posted November 25, 2004 - 07:58 PM
You can also use a left handed drill bit (got mine from the Snap-On guy). Nine times out of ten you never make it all the way through with the drill before the screw breaks loose..
  • beezer
Posted November 26, 2004 - 05:29 AM
I take a hack saw blade and make a slot across the screw head and use a flat blade screwdriver. Sometimes you have to break a piece off of the blade and use a vice grips to hold it.
  • Sparky_So_Cal
Posted November 28, 2004 - 03:44 PM
Either needle nose vice grips or just use a drill running in reverse and apply pressure. It will slowly chew the material away and also back the screw out
  • curtis515s
Posted November 28, 2004 - 04:44 PM
Go to Sears. Craftsman makes a tool called the screw out. It costs about
$ 20.00 and has 3 different sizes. This is the best tool for this.
  • wrooster
Posted November 28, 2004 - 05:07 PM
http://losdos.dyndns.../extractor-set/
jim aka the wrooster
'01 wr250f
  • Yamaha_004
Posted November 30, 2004 - 05:44 PM
Yeah the best way is with vice grips it happened to me with thoes stupid brass screws ! it helps if you bring all of your screws to a local hardware store and tell them to match them exactley to allen Wrench heads you wont be sorry. :cry: best of luck to you :cry:
  • 0 replies
  • Hot  38 replies
  • Hot  47 replies
  • 5 replies
