will 00 426 springs (both fork and shock) fit 03 450?
2 replies to this topic
  • krotchwaffle
Posted November 23, 2004 - 02:56 PM
i know i can probably make the rear fit and have success with adjusting it between the sag and the clickers, but i'm not sure if the forks are similar enough between the two to make it work. i know the outer tube is the same diameter, but i'm unsure of the internals. if worse comes to worse, it's simple enough to pull the fork springs that are in the 450 out and compare them.
any help is appreciated.
  • Matt96xr6
Posted November 23, 2004 - 04:04 PM
yes they should all work. The only difference may be the length.
  • Vetmxrider
Posted November 23, 2004 - 10:09 PM
The fork springs are the same size, 41.2 mm X 462 mm and should fit just fine.
Thanks.
Ed. :cry:
  • Hot  50 replies
  • Hot  113 replies
  • 5 replies
