22mm front spinal hex/allen (uk peeps)
8 replies to this topic
  • dangermouse007
Posted November 23, 2004 - 09:13 AM
ok boys where do you get a 22mm allen/hex for the front spindal :cry:
  • mousemeat
Posted November 23, 2004 - 09:46 AM
You mean a 22mm socket? I got mine at halfords superstore cause i was in a hurry, but would try to find one from brittool if i was all classy and organized.
EDIT: do you mean for the hexagonal hole? You dont need to worry about that. All you need is a 22mm socket for the nut and 10mm spinner/wrench. just undo the bolts and nut and push the spindle from the threaded side and it slides out.
  • dangermouse007
Posted November 24, 2004 - 02:00 AM
cheers for that ... worked it out last night..
  • Hamish
Posted November 24, 2004 - 02:33 AM
even though u have it sussed heres a tip for you guys when you need a large hex key. Find a bolt whose head is the same size as the hex fastner you are trying to work with. Put 2 nuts on the thread of the bolt and lock them together. Then you can use a normal socket or spanner to undo the fitting. Cheap and quick :cry:
  • dangermouse007
Posted November 24, 2004 - 09:09 AM
Excellent Tip many thanks..
  • RichBaker
Posted November 24, 2004 - 12:29 PM
Even better, find a cheap socket you can hammer over the threads and you have an Allen socket..... :cry:
I learned that one a couple years ago when I needed a 27mm allen. An 18mm bolt+spark plug socket worked great!
  • Jackazz
Posted November 24, 2004 - 01:10 PM
If I remember correctly, the "spark plug wrench" that comes with the bike has an end that fits the axle.
A trick I learned when roadracing from another racer is that alot of times the outside "hex" end of a spark plug socket will fit in the axle, all you have to do is pull out the rubber grommet inside the socket & put the socket onto an extension backwards. I think this works for alot of Kawasaki's forks as well (they use Kayaba too don't they?).
  • Jackazz
Posted December 09, 2004 - 09:03 AM
Update:
I was wrenching in the garage last nigt & checked... the backside (hex end) of a craftsman 5/8" spark plug socket (which, BTW is the socket that fits the WR plug) fits the front axle perfectly.
  • Endurordr
Posted December 09, 2004 - 09:54 AM
Update:
To bad I didn't see this post eariler as I've been using this trick since I got my bike. Amazing what you can find out in a 'pinch'.
