Who has the lightest WR450
7 replies to this topic
  • barefootbob
Posted November 18, 2004 - 03:34 PM
I have a 04 WR450 I love my bike :cry: but after riding my buddys crf450 I'm wondering how can I shed some weight and make some adjustments to get that light fealing :cry: I know that crf450 is a lighter bike but when you ride it it feals lighter than it realy is.What parts to use and where do I send my suspention what exhaust is light Quit and adds power.HELP! so much mud so little time :cry:
  • ncmountainman
Posted November 18, 2004 - 07:28 PM
i've got mine down to 249 lbs wet w/out gas now this is coming from 262 lbs stock wet w/out gas. there are several controversial things i've done to attain this weight,the big one being total starter removal , also removing the overflow tank and putting on a 1.6 kg cap seemed to draw some negativity. but there are many things you can do,like a light weight exhaust not only power gains but my power core 4 was 5 lbs lighter than stock! you can go to the yz rear fender thats worth over 2 lbs. the ironman sprocket is 1 lb less than stock ,that useless odo that takes forever to reset ,over a lb(including the cable,just silicone the hole) removing the starter and all the crap was almost 14 lbs and after battery removal you can then use the yz airbox (only $50) and thats another 2 lbs. i've also added around 7 lbs of extras(gaurds etc.) so technically you could go down to 242 its probably about as low as you could go and still function normally. there are other more expensive ways (titanium springs,and axles-bolts) but unless your racing thats gettin' kinda out there! :cry:
  • wr_power
Posted November 19, 2004 - 12:35 PM
You can also loose the headlight and replace your sub-frame with one from a yzf, it's aluminum instead of steel. Good luck!
  • tom_dappert
Posted November 19, 2004 - 10:45 PM
Yeah. 03 YZ450F. Headlights are for people who can't see. Good Luck.
  • ncmountainman
Posted November 23, 2004 - 03:22 PM
the headlight was one place i didn't want to lose weight! not only does it act as a buffer for the regulator, after having to come out of the woods in the dark a couple times you kinda appreciate it! i am looking at the ufo headlight which seems alot lighter anyone know what one weighs? and the 03-04 already have the aluminum subframe.
  • 98esten
Posted January 28, 2005 - 10:56 AM
did you put anything in place of the Battery? I took mine out of my 250 and it does fine.
  • RussVCHSS
Posted January 28, 2005 - 11:49 AM
Use the gas cap mod... Remove gas cap and hold in hand....roll WR about 10 feet forward from where you are standing. Go back to original place where you were standing. Now have a friend roll a YZF up to you. Put gas cap on YZF and ride that.
  • ncmountainman
Posted January 28, 2005 - 02:52 PM
no just took it out and grounded the ground strap,since that post i have removed the headlight with no ill effect. :cry:
  • Hot  50 replies
  • Hot  38 replies
  • Hot  28 replies
  • 5 replies
