changing rear sprocket from 51-53
7 replies to this topic
  • Mack_10
Posted November 18, 2004 - 09:57 AM
Sup guys, I have a 2000 426 and I am changing my rear sprocket from 51 to 53, i am currently runnind a 15 in the front and want to know what type of changes i am goin to encounter when the swap is made. Also, just want to make sure there are going to be no jetting adjustments to be made ( dont think so but not sure). Thanks guys!! :cry:
  • noslo98
Posted November 18, 2004 - 11:23 AM
Jetting??? What does gearing have to do with that?? the 15/51-53 gearing should be the same as stock just in a diferent way scince the stock is 14/48 i believe adding a tooth to the front drop the ratio so you would need to add 2-3 teeth to the back and would be back to your stock gearing. why would you do that either? just wondering.
Posted November 18, 2004 - 11:56 AM
Unless your bike needs different jetting in second gear than in fourth or fifth, you should be OK. :cry:
  • MotoX352
Posted November 19, 2004 - 11:05 PM
:cry:
  • Satch0922
Posted November 20, 2004 - 04:43 AM
What are you riding ? Motocross? I have found that 14/50 is the perfect set up for me on a motocross track. I currently ahve 14/51 set up and I am just waiting for the rear to wear out so I can go back to the 50 !!! :cry:
  • BC3
Posted November 20, 2004 - 10:37 AM
The only tip I can think of is if your on a tight budget and want good chain life..
try to make your gear ratio work out with a 15 tooth counter as upposed to a 14....
the larger radius you run you chain around the less it will where....I have a 450 and
the four speed tranny makes it kinda tough to get the best of both worlds...(LOW geared
for plonking, TALL geared for hauling A$$ in the desert......Hope this helped you..
BC
  • yz426onNOS
Posted November 20, 2004 - 12:46 PM
I ran a 13/50 for tight trails and it worked great.
  • MX2Havasu
Posted November 20, 2004 - 05:56 PM
I think you should return it and get the same one you had. YOU DO HAVE A RECIEPT FOR YOUR PURCHASE, RIGHT? LOL!
  • Hot  113 replies
  • 9 replies
  • 0 replies
  • Hot  47 replies
  • On Yesterday, 06:20 PM
