Jeff Langston _ Carb Settings
3 replies to this topic
Posted November 17, 2004 - 11:19 AM
Here are the Carb settings you asked for:
YZ/WR400F 0 to 8000 Feet.
Needle: OBEKN on clip #3 from the top
Pilot: 38
Pilot Air Screw: 65
Alternate Pilot: 40
Main: 155
Main Air Jet: 160
Fuel Screw Initial Setting: 1/4 turn OUT
Additionally You will need to purchase an RC wheel Collar and attach it to the Fuel pump rod from normal rest position UP the width of a dime and tighten the collar. (TAFFY MOD)
Ride with caution because the bike will now rip your arms off.
Good Luck,
Bonzai :cry:
  • Pothole
Posted November 17, 2004 - 01:33 PM
Good Luck,
Bonzai :cry:
I can vouch for these settings...I setup my carb this way exactly upon Yamakaze's recommendation and now my YZ400 rips like I can't believe. The bog is totally gone, and my front tire is rarely on the ground!
Posted November 18, 2004 - 12:09 PM
You still hanging around Jeff ???
Bonzai :cry:
  • rush66
Posted November 18, 2004 - 07:44 PM
WOW who thought changing the pilot jet could make so much difference and never has it started so easy :cry:
I did things a little different though
165 MJ ( change to 160 or 155 possibly )
stock 200MAJ ( I still need to order a smaller MAJ but I was wondering It rips up top would going down on the MAJ make it so I could run a leaner main without decel popping ?)
JD blue needle 4th clip ( James said it was similar to the OBEKN needle with this clip position)
40 PJ (might try a 38?)
70 PAJ
1 sec on AP with taffy mod
1 1/2 turn on fuel screw
It is a blast to be crusing along with the throttle closed and whick the throttle and loft the fron end with no hesitation :cry:
Thanks for the help with the jetting tips Yamakaze, Pothole and James Dean.
