How many beers will it take to
9 replies to this topic
  • gimprvr
Posted November 12, 2004 - 02:53 PM
install a new triple clamp and scotts damper? Just picked mine up. Can anyone give me any tips on install?. ie, "Dont do this", "Use this Tool" kind of stuff
Thanks in advance :cry:
  • ncmountainman
Posted November 12, 2004 - 03:38 PM
sounds like a two man job,better get a case!!! :cry: :cry:
  • jerryls
Posted November 12, 2004 - 04:05 PM
Make sure all the parts are there. I took everything apart, installed the new clamp and tower, and then realized that they didn't send me the floating pin that goes in the tower. Wasn't fun the next day to go riding with all the shiny and pretty new equipment that didn't do squat. My (supposed) friends were ruthless too.
  • blue_beast_wins
Posted November 12, 2004 - 05:25 PM
4 panadine forte, 4 Wild Turkey stubbies and a slab of Crown Larger should cover it :cry:
  • gimprvr
Posted November 13, 2004 - 10:01 AM
Here here :cry:
Thanks for the tips guys!!!!
  • Fryboy
Posted November 13, 2004 - 10:18 AM
When you mount the post make sure you do each of the cinch bolts a little bit at a time. Keep going back and forth until that sucka is on there nice and tight. Other than that I think it should only be a 4 beer job.
Fryboy
  • ncmountainman
Posted November 13, 2004 - 10:33 AM
Fryboy
it takes that just to get organized! :cry:
  • Dan_Lorenze
Posted November 16, 2004 - 08:29 AM
I think you should pack your steering head bearings with grease while you have the top-clamp off. It's only going to take one beer more to do it.. Also, make sure you have a nice Mallet to gently slide the new top clamp on. Be careful not to gouge the pinch area of the top-clamp with a screwdriver, if you must open up the pinch area use a tire iron instead of a screwdriver, bigger is better.
Also, make sure that the steering head nut is properly adjusted, too much torque will hurt your bearing and not enough will give your bike the shakes.
Taking old bars off= 1 beer
Taking old clamp off= 1 beer
Packing bearings= 1 beer
install new clamp= 1 beer
mount dampner post and dampner= 1 beer
install new bars w/ new grips (might as well go all the way) = 2 beers (it takes longer than one could expect)
The way I look at it, it will take you 7 beers to git r' done... Have fun....
Dan :cry:
  • gimprvr
Posted November 16, 2004 - 09:19 AM
Dan :cry:
Thanks Dan, I appreciate it the tip. If you added about 12 more beers and the makers mark shots you'd be dead on!!
  • Dan_Lorenze
Posted November 16, 2004 - 01:40 PM
I'm comin over... :cry:
