xr600r front wheel on xr650r
8 replies to this topic
  • scorch
Posted November 10, 2004 - 05:59 PM
Is it a straight up swap? Including rotor. I got a great deal on a xr600r front wheel and it looks the same.
Is there any tweaking involved?
What bikes use the same rear tire?
  • mikekay
Posted November 10, 2004 - 07:09 PM
there is a very very very slight difference between the two wheels, but you can run it.
  • scorch
Posted November 10, 2004 - 07:23 PM
I installed the wheel, but there is a bit of play in them. Is that normal?
When I installed it, locked everything in. I put my hand on the wheel and shook it, and the wheel wiggles from side to side. Is this okay to run?
  • Miker
Posted November 10, 2004 - 10:32 PM
I think you need the spacer from the XR600 setup to make this work for you. Don't quote me on that though. I would think someone would know on this site so "To the Top" :cry:
  • SaltyWalrus
Posted November 11, 2004 - 04:21 AM
Try to figure out where the play is coming from. Are the bearings the wrong inner diameter for the axle? Are the spacers the wrong width. Spacers wrong inner diameter???
I am not sure, but I thought I remembered the XR600 wheels fit, but you had to put in different wheel bearings. Let us know when you figure it out!!!
  • scorch
Posted November 11, 2004 - 06:56 AM
What are spacers? The yahoogroup xr650 list tells me I need the 600r spacers.
Where can I get them?
  • RingKingPin
Posted November 11, 2004 - 07:13 AM
If the play isn't the spokes and it's not the bearings then your going to need different sized spacers or bushings. I had to turn my own down on a lathe for my motard wheels. Where does it look like the wiggle is coming from? How do the bearings feel?
  • scorch
Posted November 11, 2004 - 07:37 AM
What are spacers? And where can I get them?
  • BajaBoundMoto
Posted November 12, 2004 - 02:14 PM
The spacer on the disc side is slightly different.
Sotck 600 spacer has a little groove around the fatter part. The 650 one does not.
If you use the 600 wheel then use a 600 spacer.
  • Hot  186 replies
  • 4 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
Washington
  • Hot  32 replies
