03 yz450..I'm a big boy
12 replies to this topic
  • viperman
Posted November 09, 2004 - 12:13 PM
I just picked up an 03 YZ450F. The thing is awesome, and
the guy I bought it from raced it and worked at shop and has
it dialed in :cry:..Its has a complete pro-pilot-tuned suspension, but he was 180 and I'm 290 with gear.....
I haven't been to englishtown yet, but plan on going this
weekend to brush up on my skills....The question is, can I,
should I, do anything to the suspension? I'm used to ride
when I was younger=lighter :cry:, but it was all trail/woods riding with very limited MX time.... Any ideas..
BTW...this place rocks. Joe. :cry:
  • Bryan47
Posted November 09, 2004 - 12:35 PM
I would DEFINATELY step up the suspension, you won't like it if you don't. (just my 2 cents). I've always rode my bike and 'adjusted' to how it rides, now that I've dialed in my suspension I'm wondering why I didn't do it years ago when I first started riding harder. :cry:
  • viperman
Posted November 09, 2004 - 12:39 PM
I agree....the question is how?
  • Guest_BrandonV_*
Posted November 09, 2004 - 12:46 PM
Take it to a reputable suspension guy. You might end up getting in over your head unless you're enlightened in the art of forks/shocks. Or..... go to heavier oil, springs and adjust rebound/compression accordingly. That you can do.
  • ncmountainman
Posted November 09, 2004 - 01:31 PM
i'm the same weight as you and use .52/6.6 but i run HS not MX i still bottom on the really big jumps. on my forks(which are the same as yours)i put in mobil 1 syn trans fluid (which is 7 1/2 weight compared to the stock 5) and then to run a little higher oil i had to add a subtank which brought it back to normal plushness. the $hit you gotta do when your bigger than average!!! oh the shock is crap that definately needs revalve,i didn't have to do the forks with the other mods. :cry:
  • Vetmxrider
Posted November 09, 2004 - 01:43 PM
I'm no expert by a long shot but I think your stock fork springs are .46kg/mm. and I bet your going to need around .52kg/mm. As for the rear, I think you may need around a 6.0kg/mm. You can post this question on the suspension forum and get pro feedback :cry: Enjoy the new bike!
  • ncmountainman
Posted November 09, 2004 - 01:53 PM
at least 6.6 on the rear,its still kinda soft even with hardly any static sag! too tech racing in cal. was the only place i could find such high rates for kyb. :cry:
  • motomike137
Posted November 10, 2004 - 08:33 AM
Start by getting it sprung for you. Then ride it and work with the clickers. I wouldn't just throw heavier oil in the forks either. Adjust on oil height and compression/rebound settings first. If you really want to make it work take it one step at a time and think about the changes you make as you go along. Do one thing at a time and then ride it. :cry:
  • slazzies
Posted November 10, 2004 - 10:29 AM
since you're a Jersey Guy, and you need to have your suspension fined tuned for you, check out Pro Pilot (they have a website, just Google it), they're right in Jersey, do good work and will turn it around fast. (find out if the guy you bought the bike from had any work suspension work done before you call/send it in)
i'm not as big as you, but at 220, i was overpowering the stock suspension, and needed work done. the difference was night and day, and well worth the $$$.
good luck, and we'll see you at E-Town
  • elsinoredaze
Posted November 16, 2004 - 09:09 AM
I'm 275 with gear...on my 05 450 I still had 15 mm static sag after adjusting race sag to 105 mm.This is with the stock spring.
After reading all these big boy posts I'm wondering if I measured the static correctly. :cry:
I know just enough to be dangerous when it comes to suspension but I would measure rear sag before changing any parts.
Posted November 16, 2004 - 09:14 AM
Buy springs to match your weight. Check with a good local suspension specialist for his recommendations. One of the best basic things you can do to the YZs is put enough spring on them so that you can ease up on the compression damping a little. Makes them much plusher. :cry:
  • flyinguitars
Posted November 16, 2004 - 09:40 AM
Yea, some stiffer springs then worry about fluid, fluid height, and clicker settings.
on a side note, I just went with a 50/50 mix of mobile 1 atf and enzo o1 weight....my forks are awesome!...im 210- 215 right now...I went one heavier on the springs and 10mm higer on the fork oil...great bottoming resistance for me now.
Viper...I got your pm last night and responded to it but the new tt software erased it. PM me again and we'll set something up....I have a 6 year old who rides a xr-50....well xr-88 now...we go to njorvp all the time.
  • viperman
Posted November 16, 2004 - 10:51 AM
PM sent
  • Hot  47 replies
  • Hot  36 replies
  • On January 15, 2017
  • Hot  113 replies
