Engine popping
4 replies to this topic
  • socalduner
Posted November 08, 2004 - 12:14 PM
My 426 has started popping and if you crack the throttle off idle it rev's very high, and wont stop until I hit the kill switch. The filter is clean and the jetting unchanged. Any Ideas? :cry:
  • Riel250f
Posted November 08, 2004 - 12:48 PM
Check the carb boots, could have an air leak.
My boot ripped (on the cylinder side) when I landed off a jump too hard.
  • yzf450jack
Posted November 08, 2004 - 08:21 PM
You might have an exhaust leak
  • socalduner
Posted November 09, 2004 - 06:48 PM
I think it was the carb boot. I was reading the instructions for the power now, and it said if the boot wasn't in the groove right the idle would be high and erratic.Thanks for your help. :cry:
  • John_Lorenz
Posted November 10, 2004 - 06:50 AM
When was the last time you took the carb apart and cleaned it thoroughly?
If the idle is hanging as you said above, then a few things can be an issue
1: Cable can be frayed, causing the hanging
2: Dirty Carb/Clogged Pilot/Fuel Airway
3: Air leak in rubber manifold (Between Carb and Head)
4: Throttle tube is damaged and hanging
I would say its time to do a very close once over on your whole assembly Throttle tube to Carb :cry:
  • Hot  113 replies
  • Hot  30 replies
  • Hot  50 replies
  • Hot  36 replies
