What Type of Coolant?
9 replies to this topic
  • Moondogger
Posted November 07, 2004 - 11:12 AM
Can I use automotive pre-mixed coolant in my WR450 or do I need a special type?
  • Seabass
Posted November 07, 2004 - 12:05 PM
Sure you can. ZipTy Racing sells some new type of coolant that is supposed to protect against boil over much better than conventional coolants. I think I'm going to buy some since my 'o5 WR just boiled over after 5 minutes of idling while adjusting the fuel mixture screw
  • Moondogger
Posted November 07, 2004 - 01:09 PM
Seabass,
The same thing happened to me yesterday, my 05 WR450 boiled over after a 5-7 min. of idling. I think the 05's run a bit lean, causing a hotter engine.
  • Texas4play
Posted November 07, 2004 - 02:03 PM
Direct a fan at the radiators during prolonged idle.
  • StreetbikePimp
Posted November 07, 2004 - 03:42 PM
Since you live in Cali, use distilled water. It works better, and it don't make a sticky mess if you spill it.
  • PSDCOOL
Posted November 07, 2004 - 04:46 PM
How can you tell if it overheats?
  • Moondogger
Posted November 07, 2004 - 09:33 PM
PSDCOOL,
You can tell it's over-heating when coolant starts spurting out the escape tube at the bottom of the bike.
  • Gadsen
Posted November 08, 2004 - 08:03 AM
OK, I'm not plugging superior Toyota coolant (ok, maybe a little :cry:) but they have a special type that contains no silicates or borates. Ideal for protection against corrosion (great for aluminum) and water pump seal(s). They have had LLC (super long life coolant) which is red and you must it with water, but use distilled water for peak performance. Now they have come up with SLLC (super long life coolant) and its already premixed at 50/50, and you just pour it in straight. Its pink in color, while the LLC is red in color. Usually coolant doesnt stay long enough in a bike to cause corrosion from electrolysis, but the water pump seal is another issue. If you go with another type, make sure it has no silicates and secondly no borates. Avoid silicates most of all!!! :cry: Its all I use, but I get a good deal on it! :cry: :cry: So if you see a WR450F with some sissy pink coolant, its me!
  • bfly
Posted November 08, 2004 - 10:08 AM
I worked at a shop dedicated to 80 series Cruisers for a time. Most of the 80 series running LLC we saw had major gunk in the radiator to the point of being plugged up. It appears the LLC is eating away at the hoses. After rebuilding the engine in my Land Cruiser (turbo + lean injector = blown motor) I went with Prestone. At the time I figured I would rather have a little wear on the water pump than another plugged up radiator.
The moral is probably more about replacing the radiator fluid more frequently than Toyota recommends for the LLC. Personally, I would replace the fluid every year or two no matter what fluid is being used.
  • dez4ever
Posted November 08, 2004 - 10:31 AM
I've just started using Engine Ice and it seems to be working pretty good. I have quite a few friends that have KTM's with overheating problems in the tight and twisty's, they all switched to Engine Ice and it helped out quite a bit. It is also supposed to be enviro friendly.
