3 replies to this topic
  • spanner
Posted November 05, 2004 - 11:27 PM
did pads and change brake fluid tried to bleed but cannot get them to work any ideas
  • ncmountainman
Posted November 06, 2004 - 06:50 AM
you have to put a clear hose on the bleeder valve into a cup of clean brake fluid,make sure the end stays in the fluid at all times. crack the bleeder compress the lever and hold,while holding the lever in, close the bleeder. repeat until air bubbles are no longer present in the hose. be careful that you don't empty the master cylinder(keep adding fluid) its way easier with two people,just pay attention because any deviation will allow air back in!! :cry: :cry:
  • Indy_WR450
Posted November 06, 2004 - 06:57 AM
Go to autozone and buy a cheap vacuum bleeder. Makes the whole process a lot easier! :cry:
  • spanner
Posted November 06, 2004 - 05:44 PM
thanks guys got them working :cry:
