changing oil
14 replies to this topic
  • dkwok
Posted November 04, 2004 - 02:12 AM
hi,
do u warm the engine up for a few minutes b4 changing the oil or
jus let it stand for a day b4 changing it,
i have conflicting versions of how it shld be done,
:cry:
  • SteadyEddy
Posted November 04, 2004 - 02:39 AM
People say to do it when it's warm as the oil will drain quicker. But I do it when its cold, I’m not racing anyone when changing the oil, and I don’t mind if it takes longer :cry:
  • The_Missile
Posted November 04, 2004 - 05:18 AM
I always do it with it warm, I hate to hang around.
Word of caution...never measure the oil level cold as you will
get a major false reading, add some....then some more and
then well, you can figure the rest.
  • Top
Posted November 04, 2004 - 06:18 AM
I always change my oil on anything I own while being warm. First time I went to change the oil on the WR I took out the frame drain plug and oil shot two feet into the front wheel!!! Grrrrrrrrrrrr :cry:
  • Endurordr
Posted November 04, 2004 - 07:31 AM
Here is my thinking on changing oil. I always used to change my oil when something was warm, thinking exactly what has been said already, drians quicker when warm, TRUE.
But then one time I tried something different, I was thinking one day that when you warm up the bike to change the oil the oil system pumps oil everywhere throughout the engine, right? Right.
But if you let the bike sit for a couple of days most of the oil comes back down to the bottom of the engine, it may drian slower when cold but you get more out after it sits. The reason I know this was because I have tried this theroy many times. I have changed my oil half a dozen different times, each time measuring how much oil I put in during an oil change. Then I would drain the oil after a ride and measure it again, each time I drained it cold I got anywhere from 25 to 50cc more oil out when it was cold.
Granted it did take longer but all of the oil had a chance to drain back down to the bottom of the frame tube and cases.
Those are my observations.
P.S. Plus it's nicer to the neighbors when you realize at 11 o'clock the night before you go riding you have to change your oil. :cry:
  • beezer
Posted November 04, 2004 - 07:43 AM
If you want to be a real nitpicker drain the oil warm and let it sit there overnight.
When you change the oil hot all the crap is in suspension not sitting somewhere where it will stay and not end up in the drain pan.
  • lewichris
Posted November 04, 2004 - 10:18 AM
i usually drain it woram and let it sit overnight. It is something i need to do tonight.
  • YamahaWR450FMike
Posted November 04, 2004 - 10:21 AM
I totally agree on your oil changing method
  • dkwok
Posted November 05, 2004 - 03:31 AM
sir,
u have a very valid piont there,
let it sit for a day or more, so all the oil is at or
around the drain plug,
thanks.
:cry:
  • Top
Posted November 05, 2004 - 08:17 AM
Does it really matter either way when you SHOULD change your oil often anyways????? :cry:
  • MotoMad
Posted November 05, 2004 - 09:26 AM
I have always thought that there were two reasons for changing the oil after warming the engine. First, warming the engine coats the engine with fresh oil. Second, warm oil will drain quicker. The main goal here is to cause the least amount of wear on your engine when starting a freshly oil-changed engine. There will be a small amount of time after starting the engine (after changing the oil) when parts of the motor are not getting oil. By having a fresh coat of oil on the components prior to changing the oil, those parts of the motor are better protected. Admittedly, this affects automobile engines more than most small motorcycle engines but it's still worth doing IMO.
  • RMarkus
Posted November 05, 2004 - 06:37 PM
This is sort of a thread hijack-sorry. I bought my WR426 used and I don't have the manual. I'm changing the oil per the instructions on the Thumperfaq. Does the oil filter have a gasket on both ends, or just on the outside? The Thumperfaq is for the 250 so I figure it may be different. I just took the filter out and there is only a gasket on the outside, not on the inner side (and it isn't in the cavity either). :cry:
  • dkwok
Posted November 08, 2004 - 06:56 AM
well, when i or we want to change the oil,
i want to make sure tat all of the old used oil comes out,
we bikers are fastidious wif our toy,
:cry:
  • BIGMatt
Posted November 08, 2004 - 07:21 AM
I change mine cold, just let it drain longer to get it all out. Plus, all the oil has drained to the bottom sump, and you dont have to drain the frame tank. Just one less oil plug to unscrew and possibly cross thread. IMO.
  • ddialogue
Posted November 08, 2004 - 08:13 AM
The Gospel according to Yamaha (the WR450 manual anyway) says to start the engine and let it warm up for several minutes.
So it is written; so let it be done. :cry:
