YZF450 exhaust cam
2 replies to this topic
  • launchzone
Posted November 03, 2004 - 04:29 PM
To all that installed a 2003 YZF450 exhaust cam in the 2003 WR450: How many pins (cam chain) between the marks (teeth) on each cam sprocket. I'm counting pins, not links. The 2 marks on the exhaust - 12:00 o'clock & 9 o'clock , the 2 marks on the intake - 12:00 o'clock & 3 o'clock. I counted 12 pins. Is this correct? :cry:(the crank is on the TDC mark). Thanks for any info.
:cheers:Steve
  • jchantzWR400F
Posted November 04, 2004 - 06:28 AM
http://www.thumperta...5/o/all/fpart/1
If the info's not somewhere in hear, I'd be surprised. :cry:
  • launchzone
Posted November 04, 2004 - 09:00 AM
Well I'm answering my posting: Its 14 pins! It looked right set at 13pins, but set at 14 pins the bike starts good even though the punch mark is slightly under the recommended position (9:00 o'clock)on the exh. cam. It has a bog if you snap the throttle, but revs out good after that. I'll turn in the mixture screw from 2.5 turns to 2 turns and go from there. Thanks for looking and any info is appreciated.
