rims
2 replies to this topic
  • 99raptor
Posted October 31, 2004 - 07:57 AM
Will my stock rimmed 2004 yz450f hold a fatter tire such as a 120/90 -19 on the rear [110/90-19 is stock],also a 90/90-21 on the front[stock is a 80/100-21]?I assume a bigger tube will be needed if the tire will hold the rim? :cry:
  • yzf450jack
Posted October 31, 2004 - 08:19 AM
Sure it will go on there! and tube is fine. If you want to change the tube get a thicker tube the stock one's are to thin :cry:
Posted October 31, 2004 - 09:39 AM
The new 90/100x21 tires are made to fit on existing rims, so no problem there.
Many 120/90 and larger tires specify a wider rim, but using the one you have won't cause any major problems. The tire will just have a little more rounded profile than intended because the beads are closer together.
Using a smaller than "right" sized tube is OK. Where you can get in trouble is by trying to stuff a bigger one into a too small tire. It can end up folded and get pinched.
