Grey Wire Mod On '05 WR
10 replies to this topic
  • Seabass
Posted October 30, 2004 - 04:34 PM
I just picked up my new '05 WR and the mechanic said NOT to cut the grey wire, but do cut the throttle stop. Is this guy high?
  • luke_n
Posted October 30, 2004 - 04:57 PM
http://www.thumperta...5/o/all/fpart/1
Looks like it is still a valid mod in 05
Why is it that no matter where you go Yamaha dealers dont know f#ck all of nothing!
  • SteadySeniorRide
Posted October 30, 2004 - 05:22 PM
Luke...
You are soooo right. :cry:
As official factory representatives with tons of resourses at their disposal, it never ceases to amaze me at how screwed up so many dealers are. :cry:
Thank goodness for ThumperTalk. :cry:
SSR :cry:
  • Top
Posted October 30, 2004 - 05:51 PM
I just left my local dealer and he looked at me like I didn't know what I was talking about when I mentioned the grey wire mod.......... :cry:
  • smp2002
Posted October 31, 2004 - 06:05 AM
I rode my 05 wr450 yesterday for the first time since I cut the gray wire and the throttle stop, it makes a big difference, now it runs like it should.
  • Texas4play
Posted October 31, 2004 - 09:33 AM
I pulled mine. Runs better. Took the advice of others and pushed it out of the connector (6 wire on '05) instead of cutting. Thought about taking a picture for the "didn't-have-a-clue" dealer but decided ...naaah, f'em.
However, if you do the t-stop and gray wire along with exahust baffle removal, be prepared for hard throttle backfire (at least at my elevation/temp - 500ft/85 deg). Thinking of re-installing snorkle until I can get ahold of the "JD" jet kit ..............sounds much better with snorkle out.
ENJOY the bike !!!
  • luke_n
Posted October 31, 2004 - 02:14 PM
I can't understand it either, surely they can create some kind of knowledge sharing database. Unorganized dirtbikers are doing it all over the world.
Texas I highly recommend the JD kit but if you think your getting a lean backfire when your winding it on hard you can adjust the standard needle up a clip (put the circlip down one notch) rather than putting the snorkle back in.
  • Indy_WR450
Posted October 31, 2004 - 03:31 PM
Lukes right and a richer pilot jet will also help. :cry:
  • Texas4play
Posted November 01, 2004 - 09:10 AM
Yeah, it's definitely lean. I've also wondered the possibility of just tweaking the fuel mix screw out richer some. Did anyone experiment this step before going into carb.?? Results?? I know I'll do the JD kit but I'm just curious.
  • r_dawg1021
Posted November 01, 2004 - 09:26 AM
The JD kit is obviously a good thing, but based on my experience the zip-ty is all I needed to get my bike going 'right'. I took the snorkle out, did the air box mod, throttle stop, etc...all I had to do was install the zip-ty and all off throttle back fire stopped. I think some people get a little carried away and don't take baby steps when doing this work themselves. Just my opinion... :cry:
  • Texas4play
Posted November 01, 2004 - 03:24 PM
[/QUOTE]
Ditto, think I'll give that a try.
