Loctite sucks!!!...in some situations.
18 replies to this topic
  • XR650R_Bob
Posted October 27, 2004 - 05:39 AM
I'm the 3rd owner of my XR and one of the previous 2 apparently put loctite on all the bolts. This usually isn't a problem but......it was apparently used on the rear fender mounting bolts too. Those bolt into thread inserts that are mounted in the rear sub-frame. Problem??? When I try to remove the bolts the insert turns too. Bolts will not come out. Does anyone have any suggestions? :cry:
  • frankstr
Posted October 27, 2004 - 08:13 AM
Try a little heat,such as a small butane torch??
Heat helps release loctites grip.....
  • Erik Marquez
Posted October 27, 2004 - 08:25 AM
As suggested,, use some heat. That is the recommended method of removal from the makers of Locktite.
  • XR650R_Bob
Posted October 27, 2004 - 09:55 AM
I don't see how I can do that without melting the fender. The only possible way I can think of is to use a heating iron, like a soldering iron or similar, and touch it to the head of the bolts. Might melt the fender a little but maybe some larger washers would handle that.
Or, worst case...a new fender. :cry:
  • NukBoy
Posted October 27, 2004 - 05:34 PM
For some parts that I change on a regular basis I use Violin rosin. It's a old gunsmithing trick and it really holds stuff on but also lets it go. It just won't let it vibrate loose. But some things are locktite, and other are safety wired.
  • tirebiter
Posted October 27, 2004 - 06:42 PM
Fender bolts locktited on? Bummer...grinder time... :cry:
  • BRP27
Posted October 28, 2004 - 04:02 AM
Use the Blue stuff, it lets go
  • XR650R_Bob
Posted October 28, 2004 - 04:13 AM
I've been told that the only fix, once the inserts start turning, is to replace the subframe. Right now I'm inclined to see if I can find a rear fender, cut off the old one and see if I can get to the inserts to at least remove the bolts. Thne maybe I can replace the inserts. :cry:
  • bosshogg
Posted October 10, 2007 - 12:09 PM
Can you get a vice-grip around the inserts?
If not, you may try drilling them out, but that would be a last resort. Maybe a bolt cutter on the head of the bolts? Or try using it to pinch the inserts so you can get a grip on them.
  • martinfan30
Posted October 10, 2007 - 12:20 PM
cross thread is better than loctite!
  • cleonard
Posted October 10, 2007 - 12:34 PM
Guys, this thread is from 2004. I think he figured out a solution by now.
  • martinfan30
Posted October 10, 2007 - 01:07 PM
i sure as hell hope so!lol
damn, thats the second time ive been suckered into an ancient thread.
  • Denn10
Posted October 10, 2007 - 01:33 PM
HOLY COW how do you reply to a thread from 04 today LMAO?????
  • martinfan30
Posted October 10, 2007 - 01:50 PM
bosshogs fault!
  • gearloos
Posted October 10, 2007 - 05:30 PM
I was gonna pm the guy and have him come on and say "OMG! thx! Ive been tryin for 4 years to get my fender off!"
LOL
  • Frank ZX
Posted October 10, 2007 - 05:42 PM
I'm the 3rd owner of my XR and one of the previous 2 apparently put loctite on all the bolts. This usually isn't a problem but......it was apparently used on the rear fender mounting bolts too. Those bolt into thread inserts that are mounted in the rear sub-frame. Problem??? When I try to remove the bolts the insert turns too. Bolts will not come out. Does anyone have any suggestions? :confused:
Use a hammer or a punch and hammer and give a couple good blows.This will usually break any bond and break loose easily.:confused:
  • Dust_Devil
Posted October 10, 2007 - 05:58 PM
Or, worst case...a new fender. :confused:
Very good tip, that or a heat gun would work great.
  • AaronBrown
Was somebody doing a search and didn't realize it was such and old thread?
Isn't bumping old threads called grave digging or something like that?
  • Dust_Devil
Oh damn...another resurected thread.....ITS ALIVE!!!!
  • 3 replies
  • Hot  35 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • Hot  60 replies
