00' 426 carb question
3 replies to this topic
  • thumpinscott
Posted October 26, 2004 - 11:32 AM
My Yamabog kept getting worse and worse. So, I said it's time to do the BK mod. Got the carb off the bike, cleaned it up, made sure everything is up to spec, and I can't get the accelerator pump to squirt. It squirts when the float bowl is off the carb thru the port, perfectly. The diaphragm looks good, but when I use carb cleaner and try to spray thru the corresponding hole, it doesn't work. It seems blocked. Is there any way to clean that out? Or am I missing something? Should I be able to get the accelerator pump to work on the bench?
  • Pothole
Posted October 26, 2004 - 11:40 AM
I had the same problem. Squirt the carb cleaner backwards through that tiny hole in the AP jet, then take a rubber tipped air nozzle and hit it hard with air. Getting that rubber nozzle sealed right on that jet is key to blowing out the single grain of sand or rust from that jet. Taking the needle out makes it easier to get to that little jet.
  • thumpinscott
Posted October 26, 2004 - 11:46 AM
Thanks, going out to the garage right now to give it a whirl!!!
  • thumpinscott
Posted October 27, 2004 - 04:43 AM
Worked perfectly, thanks for the tip.
  • 10 replies
  • 9 replies
  • Hot  50 replies
