hanging idle 00 426
5 replies to this topic
  • s3706
Posted October 26, 2004 - 09:51 AM
I change the stock exhaust cam with an 03 auto decomp cam. I also change the stock fuel needle adjustment to an easy adjust fuel needle. The bike fires up after a couple kick and idles but it seems kind of rough. I have the fuel needle adjusted out 1 1/2 turns. I let it warm up and crank the throttle a couple of times and the idle seems to hang. When it comes back down it idles rough and wants to stall.
  • YAMAKAZE
Posted October 26, 2004 - 09:56 AM
Whats the pilot jetting set at. 1 1/2 turns is the max it should be turned before changing the Pilot Jet and PAJ.
Bonzai :cry:
  • s3706
Posted October 26, 2004 - 09:59 AM
I am assuming it is stock, but I will have to look.
  • s3706
Posted October 26, 2004 - 10:11 AM
If the pilot jet is stock should I go up one size.
Posted October 26, 2004 - 11:07 PM
I know you already checked it, because you were just in there when you did the exhaust cam, but one cause of these symptoms is one or more tight intake valves.
  • klokard
Posted October 27, 2004 - 05:39 AM
It's possible you are sucking air through the intake boot also. Make sure you have your carb seated and snugged down. A small dab of vaseline on the boot helps also. Good luck.
  • 5 replies
  • Hot  30 replies
  • Hot  50 replies
  • Hot  36 replies
