450 YZ COUNTERSHAFT SPROCKET
5 replies to this topic
  • ktmmax
Posted October 26, 2004 - 04:07 AM
My best friend has a 450 YZ (2003). It appears there is an oil leak at the countershaft seal. It looks like a double nut setup on the sprocket and I tried to take the sprocket off but the nut won't budge. Any tricks to this? I don't have a manual on this bike so I am looking for help.
Thanks :cry:
  • GreggT
Posted October 26, 2004 - 05:05 AM
There is only one nut. I'm sure you did but did you bend the lock washer away from the nut. I use an air impact to take mine off but don't remember if it is a backward thread or not.
  • felony
Posted October 26, 2004 - 09:39 AM
it'll be easier if you leave the chain on and have somebody hold the rear brake while you hit it with an impact wrench,it should be standard threads,"righty tighty,lefty loosey" :cry:
  • noslo98
Posted October 26, 2004 - 10:24 AM
When I change mine i usaly sit on the bike and hold the back brake whie using a breaker bar to bust loose all though air ia a lot nicer when your gearing at the track somtimes you dont have acess to a compressor.
  • Scooter426
Posted October 26, 2004 - 03:39 PM
yep rear brake dude.
impact wrench/air assist helps.
Posted October 26, 2004 - 04:30 PM
When using impact wrenches, air or electric, DO NOT "hold" the sprocket by placing the transmission in gear. The battering the gearbox will take will not be beneficial.
I can usually just grab it with a rag in hand and run the nut off or on that way, but a rag and a big pair of pliers, or the chain and brake method are OK too.
  • Hot  28 replies
  • Hot  50 replies
  • Hot  38 replies
  • Hot  36 replies
