bike shuts off
3 replies to this topic
  • thumptoy
Posted September 05, 2002 - 09:17 PM
Have a problem, need some advice.
I have a 90 xr600r It doesn't seem to stay running.It will start when I kick it over but will
stop 10 sec. later. At first I thought I needed to switch it to reserve, so I did. While I proceeded to kick it again gas was coming out of
the small line at the bottom of the carb on to the ground. I looked in the tank, I had enough
gas for it NOT to be on reserve. so I switched it back to ON. It stopped leaking gas. Then I tried again With choke on half, it fired for another 10 sec. then the same thing.
Any suggestions or advice would be great. :) :D
  • Nick_L
Posted September 05, 2002 - 09:43 PM
Sounds like there may be too much air getting to the carb. Have you looked into this yet? Just a suggestion. I have a xr250 that the boot between the carb and cylinder was cracked. The bike would start for 10secs or so then die.
  • mwespo
Posted September 05, 2002 - 10:03 AM
You need to check the float needle and seat . It sounds like the needle is not closing and the fuel is going out the overflow tube. That is where I would start!
  • thumptoy
Posted September 05, 2002 - 10:19 AM
Thanks for your suggestions, I'll look at these possible probs.
Washington
  • Hot  32 replies
Honda XR650L 2016
  • 0 reviews
  • 9 replies
  • Hot  35 replies
  • Hot  186 replies
