650L Jetting...again!
7 replies to this topic
  • Winter_Hawk
Posted October 20, 2004 - 06:23 PM
Hi guys,
I know this gets asked all the time, but I can't determine what's right for all of my circumstances. All I know is I want more power and better throttle response. I KNOW I must be running lean, but don't want to choose the wrong jets.
Here goes:
'03 650L
WB E Series pipe
desmogged
snorkel removed
5000 ft
Anybody have a similar setup? What's best?
And what to go to after I drill slide and shim needle (sometime this winter)?
  • Winter_Hawk
Posted October 20, 2004 - 06:25 PM
Oh yeah.............Thanks in advance!
  • MotoChris521
Posted October 21, 2004 - 05:03 AM
I'm not sure about 5000 feet,but at 2500 ft. with a simalar set up i used a 165 main,55 pilot,needle shimmed .040" and slide drilled (5/32")i think. :thumbsup:Oh, and limit tab ground off air mix screw and out about 2-2 1/2 turns. :cry:
  • XR650L_Dave
Posted October 21, 2004 - 08:39 AM
Jetting will likely be the same after drilling and shimming.
You've got to pull the carb, do the slide- you'll LIKE IT!!
Dave
  • ghoti
Posted October 21, 2004 - 09:08 AM
Get rid of the stock air filter too.
  • Winter_Hawk
Posted October 26, 2004 - 09:42 AM
What do you recommend for an air filter? UNI? Also, what manufacturer's jets should I buy and where should I get them from?
Thanks,
Brian
  • robin52
Posted October 26, 2004 - 11:50 AM
Hey
I have an 02 and an 05 650L. We are in Tn/NC and our riding will go from 800ft.to 5000ft. I am looking for the same help.
Good luck
  • XR650L_Dave
Posted October 27, 2004 - 08:29 AM
The uni and K&N filters are both good.
Jets: www.sudco.com, www.bajadesigns.com
get their ph# and call 'em, it's a lot easier for jets that way.
Dave
