2004 YZ450 Jetting
8 replies to this topic
  • Scooter426
Posted October 20, 2004 - 04:46 PM
I just got a 2004 450 and need help with the jetting setup.
It is basically stock. I live at sea level in Seattle, and am experiencing 1/8 throttle surging. It seems to run fine everywhere else, but the fuel screw seems to have no effect on the problem. Please let me know what settings work for a basically stock setup. it does have a flywheel weight and I changed the air filter to an aftermarket one (No change in the problem). Pipe is stock 2004. I am guess it is lean surging, I have heard these bikes are lean as delivered.
TIA,
Scott :cry:
  • ovrrdrive
Posted October 21, 2004 - 12:23 AM
Try going up one pilot jet size at a time and make sure the end of the fuel screw hasn't been broken off in the hole. I know some of the aftermarket screws have a bad habit of breaking off if you seat them too tighly.
If its stock, it should have a 42 in it, try a 45.
  • Gizabious
Posted October 21, 2004 - 02:21 AM
I richened the pilot to a 45 and leaned the needle by 1 clip position, i know seems strange but this cured the surging when the throttle was at a constant position between 1/4 and 3/4 open. The larger pilot gives real good throttle response off idle
  • Scooter426
Posted October 21, 2004 - 08:37 AM
so stock settings are
pilot: 42
Main: 165
and I should change to:
pilot: 45
main: 168
sounds like the aftermarket fuel screw is a good idea, also.
Are there any differences in the 2003 and the 2004 in the Carb/Jetting/Engine settings?
thx,
scooter
  • ovrrdrive
Posted October 21, 2004 - 09:10 AM
That's what I went with. I also raised the needle one clip to richen the mid a little. The bike runs great but does surge a little at half throttle. I'm thinking the cool air will cure that soon enough though. I don't think I'll mess with the needle any.
I'll probably drop the 170 MJ in when it cools off.
As for the Zipty fuel screw, I love mine. It's worth its weight in gold.
  • Scooter426
Posted October 21, 2004 - 04:04 PM
found a 45 pilot and a 168 main in the ole' tool box. I will change the two asap and let you know how it goes. And I will but the needle one clip richer(down).
-scooter
  • YZ250F_Rider
Posted October 21, 2004 - 04:09 PM
I couldnt find a better thread to throw this in...
I just put the new cdi unit in. It is without doubt where they killed most of the low rpm power at. If you are one that likes a hit when you pin the throttle, Just swap out the cdi. :cry:
  • yzf450jack
Posted October 21, 2004 - 08:28 PM
My 03 runs like it is lean at 1/8 throttle I can't make it stop i even put another carb on it. and it does that same thing at that rpm :cry: It run's great It just sounds bad at that rpm I think it's a CDI thing :cry:
  • ovrrdrive
Posted October 22, 2004 - 12:57 AM
Cool! :cry:
Does this mean no more granny '05 jokes? :cry: :cry: :cry:
  • 3 replies
  • Hot  50 replies
  • Hot  38 replies
  • Hot  47 replies
