Damping
2 replies to this topic
  • redrider650r
Posted August 12, 2002 - 11:37 AM
Can someone please explain Damping to me?
  • Portland_650R
Posted August 12, 2002 - 01:43 PM
Think of a spring from a ballpoint pen. When you push down on it, then let go, it immediately springs back. If you put a shock absorber (or damper) inside the spring and did that, it would not spring back; rather, it would slowly return to its original length. Damping is a sort of counterforce - cushioning and delaying a shock or impact. Most motorized applications use fluid forced through small holes or around corners - you can compress the thing, but not instantly.
Its impact on dirt riding - I'm sure others will elaborate - is this:
Too little damping will have you bottoming and topping out on large bumps - you will be bouncing around. Too much will make your wheels hop - the wheel won't be able to keep up with the changes in the terrain surface. Unbalanced damping will change your handling quite a bit.
  • redrider650r
Posted August 13, 2002 - 06:23 AM
Thank you for your information.
Washington
  • Hot  32 replies
  • 22 replies
  • Hot  35 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  29 replies
