Cooling Fan For 650R
11 replies to this topic
  • Bolts16
Posted August 09, 2002 - 11:18 PM
Is there a radiator cooling fan available for the 650R through Honda/HRC or any aftermarket companies?
  • billyj7175
Posted August 10, 2002 - 12:55 AM
I was wondering when this subject was going to come up. I haven't ever seen anything aftermarket, but I would think that a quick stroll through a motorcycle salvage yard looking at various street bikes, would come up with a solution. I didn't check where you are from, but I do know that California models especially were equipped with them. You could rob the whole setup, temp sensor, fuses, connectors and all. I would think that you would only really need one fan to do the trick.
If not there, maybe Radio Shack, or even J.C. Whitney???
This brings to mind another issue...when I installed my Works Connection rad guards, I noticed that it looks as though they would restrict the exiting air through the radiators. I guess I don't ride enough slow-technical trails, so I haven't boiled mine yet, but I always do keep an eye on it. The guards do look like they would be an easy candidate for mounting a fan though.
Speaking of which...doesn't the Kawasaki KLR650 have a fan?
  • qadsan
Posted August 10, 2002 - 06:39 AM
This has already been done by several "Do-It-Yourself" type people and one person even wrote up their details about doing this. Here's the link, but you'll have to also join XR650R Yahoo group to see it.
http://groups.yahoo.... to The BRP.doc
  • Craig_Mitchell
Posted August 10, 2002 - 08:02 AM
I see that you live in Florida, which is a lot
warmer than Scotland, but are you certain that
your type of trails will need a fan. I have
owned my xr650 since April 2000 and have listened
all over the net to owners reports. Even from
owners in hot countries / states I have heard
next to nothing over the past 18 months about
needing to fit a fan. I presumned that this was
because all the North Americans had sorted
all their overheating issues by proper uncorking.
I think that after proper uncorking even the
tightest trails or the most dense traffic jams
will not cause the xr650r problems.
just my opinion, cheers, Craig
  • Guest__*
Posted August 10, 2002 - 11:33 AM
buy yourself a 1.6 or 1.8 radiator cap and your xr will never boil over again.
no need for a cooling fan, just added weight.
  • Dave61
Posted August 10, 2002 - 06:29 PM
The KLR 650 does have a cooling fan that does a great job. If you try a retrofit, besides the temp sensors and related equipment you would need to to power up the stator and probably add a battery to provide the extra electrical capacity required.
  • Bolts16
Posted August 11, 2002 - 12:29 AM
Thanks for the info guys. I sure do appreciate it. The reason I asked is I am looking at purchasing a 650R and registering it to ride on the streets. It can get extremely hot in the afternoon where I live (Florida) and was concerned about damaging the engine because of high temps it would see in stop and go traffic.
  • Guest__*
Posted August 11, 2002 - 08:07 AM
i'm from FL and my xr650r dont need no fan.
why don't you save yourself some $$ and buy mine?
'00 xr650r HRC kit...$3500 beans.
  • DR.Zaius
Posted August 11, 2002 - 04:02 PM
I put a PC fan in from my old Mac. Works pretty damn good, gonna put another one on the left radiator as well if I see the need. I just have mine hooked up to a switch on the handlebars. When in tight stuff, I flip the switch on. When in the open, shut the fan off. It even stands up to being soaked with water, after it drys out. :)
  • Ken_Jones
Posted August 11, 2002 - 06:36 PM
My ride yesterday caused my pig to overheat slightly after some rather rigorous half gear romping. Very very tight twisty stuff that requires very low first gear riding. I admit, this is not the kind of stuff the bike shines in, nor was it designed for I'll bet. In these types of situations you can ill-afford to slip the clutch much either, as this activity usually pushes her over the edge to the boiling point...! The PC cooling fan sounds like a great idea to me... :) What was the part # for that fan?
Ride on...!
  • DR.Zaius
Posted August 12, 2002 - 07:41 PM
Ken, just go to your Radio Shack and ask for a pc fan, and look for the highest CFM output for the fan, and that will be good. Only a few bucks at most, but I stripped mine from my mac....I knew it was good for something. :)
  • heydude
Posted August 18, 2002 - 08:29 PM
A PC fan might be a little small as the normal size fan is 3''. Ask for a something like a 6 or 7 inch case fan, sometimes they are also called computer exhaust fans. thinkin about this is bringin me back to my watercooled overcocked dual processor super bedroom heater days. i love being a geek. Cooling system on that computer was almost as big as one on a honda civic.
