Mystery Screw
4 replies to this topic
  • Dave61
Posted August 06, 2002 - 07:39 PM
I just pulled the head off my '01 650R in order to get the valve guides replaced. (see Blowing Blue post of Aug. 6). Thanks to the people who responded.
As I removed the carb I found a brass bolt that goes from the outside to the insde of the carb throat on the upstream side. It is at the 11 o'clock position. Any idea what it is for? Would a Scottoiler be able to use the vacuum produced here? :)
  • petee_g
Posted August 07, 2002 - 05:52 AM
sorry, can't help you w/ the 1st question.
what about baja designs? I've had some interesting experiences with them...
  • jaybert600
Posted August 07, 2002 - 08:18 AM
Is it the bolt on the head (intake area) or the carb?
  • Dave61
Posted August 08, 2002 - 04:23 AM
The bolt is on the head itself, not on the carb body. It is about 0.5 inches from where the carb butts against the head.
Sorry for the confusing earlier description.
  • jaybert600
Posted August 08, 2002 - 04:55 AM
It sounds like the port where the smog pump for the California model draws a vacuum from (nothing to worry about).
  • 9 replies
  • Hot  60 replies
  • 4 replies
  • Hot  29 replies
  • 3 replies
