Rear Preload Adjustment Help
4 replies to this topic
  • BBD
Posted August 05, 2002 - 08:58 AM
Y2K 650R: How the heck does one adjust the shock preload? I can barely see the collars, let alone get at it. Is there a special tool? I hate using the screwdriver and hammer method, and I can barely get one in there as is. Do you have to yank the air boot?
Also, any thoughts about settings? I was just going to go for 100mm for my mix of trail and MX.
  • jaybert600
Posted August 05, 2002 - 10:36 AM
The easiest way that I found is to loosen the locking collar and remove the rock guard, then physically turn the spring by itself to adjust (bike must be on a stand).
Hope this helps!
  • FooBarr
Posted August 05, 2002 - 04:24 PM
The only way I've found to adjust the shock is to remove the seat, muffler, & and side panels. Loosen the airboot on the carb. remove the top bolt of the subframe and loosen the two lower remaining bolts a few turns. Should be able to gently push the subframe back and down about 4-6 inches exposing the shock. I use a big punch and a rubber hammer, it tends not to eat up the locking rings as bad. 1 full turn is 5mm of sag. There's other good suspension info at:
http://www.motocross...cle/suspen.html
If anyone has an easier method please post.
  • Portland_650R
Posted August 06, 2002 - 08:32 AM
I do it the same way as others - take the right sidecover off, seat off, etc. until I can get at it. Then it's the ol' hammer and screwdriver...
  • stonewall
Posted August 06, 2002 - 01:04 PM
Jaybert600 is right on. Just loosen the locking collar and turn the spring with your hand.
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 22 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  29 replies
Washington
  • Hot  32 replies
