Engine Cooling
2 replies to this topic
  • RunAnywhere
Posted July 27, 2002 - 03:48 AM
I'm just breaking in a 10.25:1 Wiseco and a high performance cam. I have an IMS so I installed a remote oil filter to help cool. Now that I've jumped 2.25 points of compression, my concern is back on my overheating problem. Isn't there a bolt on shroud somewhere?
Please help with input, I'd hate to start another rebuild.
  • billyj7175
Posted July 27, 2002 - 10:24 AM
I'm not sure which bike that you're talking about, but I'm assuming its the XR600 since you mention the IMS 4.6.
To address your cooling issue, I have seen several 600's with a XR400 oil cooler that mounts on the headstay of the frame, right underneath the headlight. I saw this setup for sale on some XR website, but I don't recall what the name of the site was. I do remember that it cost around $400 though.
I'm no guru, but I would think though that if the jetting was correct, and the oil filter was in the right way, you really shouldn't have a overheating issue, unless you run at wide open throttle all of the time. Either way, good luck and I hope you get it figured out. Back when I was in my teens, I had a XR250 that I thought was overheating, but it turned out that some silicone sealant had broken off from the valve covers and plugged a journal, and slowed the oil supply to the camshaft, and the cam seized in it. I've heard of XR6's doing this with the oil filter installed backwards.
  • RunAnywhere
Posted July 28, 2002 - 03:39 AM
Thanks, Billy...
It's a 93650L. I already have one remote oil cooler. My concern with a second would be pumping those extra 2 quarts through 8 foot of line. I found cooling fins that are supposed to drop the temp. by 30 degrees for $250. It still seems that there should be a shroud.
Of course, several people say the right jetting is all it needs. I tend to agree, but hearing from someone with similar exp. would make a $650 gamble seem a bit less like gambling.
  • 9 replies
Washington
  • Hot  32 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 3 replies
