Need help with jetting.
5 replies to this topic
  • Motone82
Posted October 16, 2004 - 06:55 PM
I have a 2000 YZ 426 with a Pro Circuit T-4. I just put the pipe on and it runs like crap. Popping very bad. I called Pro Circuit and they said they didnt have any books on the jetting for my bike. Cna anyone please steer me in the right direction? Thanks
  • Fastest1
Posted October 16, 2004 - 07:20 PM
I am assuming it was running great with the stock pipe? Does it pop under acceleration or deceleration or both? Does pulling the choke help? Usually if the pipe actually increases power, you will need more fuel. Tell us where in the power it is acting up (low, med or high throttle)? Does it start well? Have you changed fuels? Is it alot colder where you are all of a sudden?
  • WR426madness
Posted October 16, 2004 - 07:27 PM
Dude try a 160 main, stk pilot jet, fuel screw 2 turns out, needle 3 nothch from the top. :cry:
  • Motone82
Posted October 16, 2004 - 08:22 PM
Ok here goes. I had a DSp pipe on it. 172 main and I believe 46 pilot. Ran great. Switched to the T-4 and it starts ok but doesnt idle well and pops like mad decelerating. Wants to die when I come to a stop. Thank you guys for your help.
  • YZ250F_Rider
Posted October 16, 2004 - 10:04 PM
turn the fuel screw out a 1/4 turn and see if it helps. Also check that the float works correctly.
  • ovrrdrive
Posted October 17, 2004 - 02:49 AM
Read this article to understand a little more about jetting then try setting your fuel screw the way they describe in the article.
http://www.atlanticm.../00000135.shtml
If mine were that lean, I'd see what jets were in it and go up one level on the pilot and main and see how it runs from there.
  • Hot  47 replies
  • Hot  50 replies
  • 9 replies
