01, yz426 float problem?
2 replies to this topic
  • rcastor426
Posted October 15, 2004 - 03:57 PM
Ok, was riding the bike and it just died, i have traced it to not getting fuel into the float bowl, i removed the float and to my surprise the needle vavle did not fall out. now i have been looking at it and there is a little nipple that moves in and out.... is that all that is supposed to move or is it the needle vavle like on an old style carb with? i tried to pull on it and it will not budge so i am just wondering if i have dirt stuck on top of it or the valve is frozen?
  • cowboyona426
Posted October 15, 2004 - 04:04 PM
Yuk. The needle valve should come right out, sounds like you've got a problem.
  • YZ250F_Rider
Posted October 15, 2004 - 04:05 PM
the needle valve and seat are exactly like old style carbs. the needle is about a 1/2" long and has a soft triangular tip on it that closes the fuel flow off.
If you take the pin out for the float, the float and the needle should come out as a unit. The needle is hung to the float with a small diameter wire.
I have seen the tit on needles wear so that they can wedge themselves in the seat. But a BIG screw driver will remove the seat and the needle so you can easily replace them.
replace the float at the same time.
  • 0 replies
  • 10 replies
  • Hot  30 replies
  • Hot  113 replies
